Best 2.5 2TB Disk for Data: Comparing Barracuda HDD & Firecuda Hybrid - Durability & Warranty
majster-klepka07 2967 17
Should I buy a 2 TB 2.5-inch Barracuda HDD or a FireCuda SSHD for data storage, and will the SSHD’s 8 GB flash cache wear out from frequent writes?
For data storage, the SSHD’s 8 GB flash cache is not a reason to pay extra; a regular HDD is enough, and the 5-year warranty on the FireCuda is the main advantage if the price is acceptable [#16953792][#16953197] The SSD part is not something to worry about here, because drive lifetime is unpredictable anyway and HDD reliability is partly a lottery [#16953828] One reply also noted that for 2 TB in 2.5-inch form factor, Seagate models are basically the available option [#16953792] So the thread’s practical advice is to choose the drive with the longer warranty rather than expecting the SSHD to be meaningfully more durable [#16953197][#16953792]
  • #1 16953108
    majster-klepka07
    i have ssd and win system on it. besides ssd, i wanted to buy a 2tb hdd for data.
    1 Barracuda Drive
    Link
    2 Firecuda disc
    Link
    The former is a regular hdd, while the latter is a hybrid of ssd and hdd - it has 8GB SSD memory. Will this hybrid SSD memory wear out due to frequent data writes like normal SSDs, and will therefore be less durable than regular hdd? I would like to add that the Barracuda has a 2-year warranty, and the Firecuda hybrid has a 5-year warranty.
    thanks for the info and cheers
  • #2 16953197
    sylweksylwina
    Help: 1882
    Rate: 2355
    Well, probably how semiconductor memory can wear out. But there is probably a longer service life for this SSD as well as the HDD. It's better to take a drive with a longer warranty.
  • #3 16953738
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8293
    See also the Toshiba P300 - 2TB or 3TB. It will be cheaper and the quality will probably be similar (considering that the durability / reliability of all HDDs seems to have dropped significantly recently). SSHD for storage is not needed, regular HDD is enough.
    Edit: P300 is 3.5 "disk, Author is looking for 2.5", so P300 is not suitable.
  • #4 16953750
    majster-klepka07
    I know that an ordinary hdd would be enough for me but I am tempted by this 5-year warranty on sshd.
  • #5 16953781
    sylweksylwina
    Help: 1882
    Rate: 2355
    WD Black also has 5 years of GW.
  • #6 16953788
    majster-klepka07
    but he is at 7200rpm
  • #7 16953792
    dt1
    Help: 7315
    Rate: 8293
    I even missed that this is a 2.5 "disk. If it is supposed to be 2TB, then only the Seagate ones. Due to the speed to SSHD, I would not pay extra, due to the warranty, it is probably worth it, because there is a good chance that within 5 it will be useful for years.
    WD Black 2.5 "seems to be hard to buy in the 2TB size (on the WD website they only admit to the 1TB models from this series).
  • #8 16953804
    majster-klepka07
    you think that obscure hdd drives are so shabby, it's actually better to take with 5 years of buzz.
  • #9 16953807
    dt1
    Help: 7315
    Rate: 8293
    Yes, this is my impression (supported by a large number of bills of lading when it comes to shipping HDD for complaint).
  • #10 16953828
    sylweksylwina
    Help: 1882
    Rate: 2355
    In fact, I somehow missed that it was about 2.5 '
    I wouldn't care about the lifetime of semiconductor memory.
    When it comes to HDD lifetime, it's a bit of a lottery. One person will work without problems for years, another will fall after a month ... I saw a laptop crash on GW, and the newer HDD 3.5 I bought in December 2014 one of the first Seagate ST1000DM003 (1ER162) releases and how to so far it poses no problems.
  • #11 16954855
    majster-klepka07
    I am attracted by such a disc
    Link
    admittedly only 2 years warranty, but 4TB :) only 3.5 "
    Will such a cable power this 3.5 "drive in the laptop? Link
  • #12 16955679
    dt1
    Help: 7315
    Rate: 8293
    They won't. If you want an external drive, that's not the way to go.
  • #13 16958401
    majster-klepka07
    and what to buy better -1 2TB disk or 2 1TB disks?
    Greetings
  • #14 16958449
    sylweksylwina
    Help: 1882
    Rate: 2355
    What is the destination for the disk? Do you have so much space in this laptop? Certainly 2 disks mean more energy consumption ...
  • #15 16958460
    majster-klepka07
    1 disk would be in the pocket instead of DVD and 2 connected with such a cable to usb 3.0
    Link
  • #16 16958704
    sylweksylwina
    Help: 1882
    Rate: 2355
    Such a connection via USB is pointless. You can easily damage the drive without the housing .... Better to buy a ready-made housing.
  • #17 16958775
    majster-klepka07
    but should I buy 2 disks or only one bigger?
  • #18 16958832
    sylweksylwina
    Help: 1882
    Rate: 2355
    Do you want to carry an additional external drive? I wouldn't feel like it.
    In case of failure of one disk, you lose some data when you have 2 disks. If you have one disk, you lose everything. So no solution is perfect. And so a backup would be useful, or RAID 1 on two 1TB disks - then you have 1TB for data storage in excess.
The discussion centers around selecting a 2TB storage solution, comparing the Seagate Barracuda HDD and the Firecuda hybrid drive, which incorporates 8GB of SSD memory. Concerns are raised about the durability of the hybrid drive due to potential wear on the SSD component from frequent writes, contrasting with the Barracuda's 2-year warranty against the Firecuda's 5-year warranty. Participants suggest that while the Barracuda is a reliable choice, the longer warranty of the Firecuda may offer better long-term value. Other alternatives like the WD Black and Toshiba P300 are mentioned, although the latter is not suitable due to size constraints. The conversation also touches on the implications of using multiple smaller drives versus a single larger drive for data storage, emphasizing the importance of backup strategies.
TL;DR: For 2TB in 2.5-inch, 1 vendor dominates; “SSHD for storage is not needed, regular HDD is enough.” Choose on warranty, not cache. [Elektroda, dt1, post #16953738] Why it matters: This FAQ helps laptop users pick a durable 2.5-inch 2TB data drive without overspending or risking avoidable failures.
Which is better for pure data storage: Barracuda HDD or FireCuda SSHD?
For storing files, SSHD speed doesn’t add value. Pick based on warranty and price. “SSHD for storage is not needed, regular HDD is enough.” [Elektroda, dt1, post #16953738]
Will the FireCuda’s 8 GB NAND wear out faster than an HDD?
Semiconductor memory does wear with writes, but the small cache and controller policies limit impact. A forum expert wouldn’t worry about its lifetime in this use. [Elektroda, sylweksylwina, post #16953197]
Are there many 2TB 2.5-inch options?
In this size, the thread identifies only Seagate 2TB 2.5-inch models. That narrows your choice to Barracuda or FireCuda. [Elektroda, dt1, post #16953792]
Does the FireCuda’s longer warranty make it a safer buy?
If warranty peace of mind matters, the longer SSHD warranty can be worth the premium. It may prove useful within five years. [Elektroda, dt1, post #16953792]
Is WD Black a good alternative at 2TB in 2.5-inch?
WD Black carries a 5‑year warranty, but 2TB 2.5-inch availability is limited per the discussion. Confirm stock before planning around it. [Elektroda, dt1, post #16953792]
Can I power a 3.5-inch HDD from my laptop with a USB–SATA cable?
No. A simple USB–SATA cable won’t power a 3.5-inch drive from a laptop. Use an external enclosure with its own power. [Elektroda, dt1, post #16955679]
Is it safe to run a bare drive over USB without an enclosure?
Avoid it. Running a naked drive over USB increases damage risk. Use a proper external enclosure instead. [Elektroda, sylweksylwina, post #16958704]
Should I buy one 2TB drive or two 1TB drives?
Two drives use more power and are less portable. With two, a single failure loses part of data; with one, you lose all. Consider RAID 1 if redundancy matters. [Elektroda, sylweksylwina, post #16958832]
Do two disks in a laptop draw noticeably more power?
Yes, two disks mean higher energy consumption. Check your bay space and power budget before adding a second drive. [Elektroda, sylweksylwina, post #16958449]
Is HDD reliability getting worse, or is failure random?
Expect variance. One drive can fail early while another runs for years. Treat HDDs as a reliability lottery and keep backups. [Elektroda, sylweksylwina, post #16953828]
Does 8 GB of SSHD cache help with storing large media files?
Not much. The small cache favors repeated reads of hot files, not bulk cold storage. Prioritize warranty over cache size here. [Elektroda, dt1, post #16953738]
What’s the practical difference between 5400 rpm and 7200 rpm here?
The thread notes WD Black models at 7200 rpm, but availability at 2TB 2.5-inch is unclear. Choose based on what you can source reliably. [Elektroda, majster-klepka07, post #16953788]
How do I add a second 2.5-inch drive using the optical-bay caddy?
  1. Install a compatible HDD/SSHD into a laptop optical-bay caddy.
  2. Secure it and insert into the DVD bay slot.
  3. Initialize and format the drive in the OS before use. [Elektroda, majster-klepka07, post #16958460]
Should I pay extra for SSHD speed if my OS is already on SSD?
No. With the system on SSD, SSHD benefits shrink for data storage. Choose a regular HDD unless the longer SSHD warranty sways you. [Elektroda, dt1, post #16953738]
Any edge cases I should plan for?
Yes. A brand-new laptop drive can still fail under warranty, while an older desktop drive may run flawlessly for years. Backups are non-negotiable. [Elektroda, sylweksylwina, post #16953828]
If I must go external, what’s the safer approach?
Use a ready-made USB 3.0 enclosure for 2.5-inch drives. It protects the disk and provides proper power and connectors. [Elektroda, sylweksylwina, post #16958704]
