VORDON HT-175BT Car Radio Overheating and Distorted Sound After Few Minutes of Use
Lukas7171 4125 7
  • Overheating occurs even with speakers disconnected
    #1 16887379
    Lukas7171
    I have had a radio for half a year, and at the beginning everything was ok. Until one day, the radio after a few minutes of playing began to grunt and so warm up that you can't catch it, it's the radiator at the back. The radio literally comes with 10 min. and it rang so much that you can't listen. I went to the electrician and advised me to disconnect the speakers one after the other and check if it would be the same. Today I checked it and it's the same ... It doesn't matter if I have a radio on one or all speakers. I have no idea if the radio is thrown away or the installation fault. I will add that when it overheats strongly, the radio turns down the music.
  • #2 16887419
    emlo
    Rate: 25
    Unfortunately, without opening the radio and the meter in your hand no one will help you, you must at least locate the overheating element.
  • #3 16888966
    aaanteka
    Help: 729
    Rate: 1195
    Obvious signs of end-stage damage. It is probably implemented on some monolithic system. It should be located and the label should be written. Most of these types of systems are generally available at an affordable price. For example: -TDA7388 - AUDIO 4x45W 8-18V 4R 10% amplifier.
  • #4 16888992
    zworys
    Help: 519
    Rate: 573
    I had an almost identical symptom after improper use of the start rectifier on the site. The monolithic power amplifier was damaged. He warmed up (admittedly not so much) even without an input signal.
  • #5 16889036
    zlota_raczka
    Help: 10
    Rate: 25
    Guess the guess? There are many factors that can affect this. If it gets hot, take it out and tell it where
  • #6 16889746
    aaanteka
    Help: 729
    Rate: 1195
    I wonder what other factor can affect the excessive heating of the monolithic system and the obvious occurrence of signs of damage - overheating? Monolithic systems of power amplifiers, including in particular multi-channel ones, are particularly sensitive to any overloading and overheating due to the design with limited thermal pad. It is doubtful that a four-channel amplifier could survive overheating.
  • #7 16893025
    Lukas7171
    So you write that it is obviously the fault of the radio ... I wonder what are the costs of such an event ... The radio overheats on the heat sink at the back.
  • #8 16894518
    aaanteka
    Help: 729
    Rate: 1195
    If you don't decide and spin it up, you'll never know. You have the receiver in your hands and you can specify the type of system. You got an example of the cost in the previous answer, or rather the commonly used 4 x 45 W system. You can easily enter in the search engine and find prices :D .
The discussion revolves around the overheating and distorted sound issues experienced with the VORDON HT-175BT car radio after a few minutes of use. The user reports that the radio becomes excessively warm, particularly at the heat sink, and produces distorted audio regardless of the number of connected speakers. Responses suggest that the problem may stem from a damaged monolithic power amplifier, possibly due to overheating or overloading. Participants recommend diagnosing the overheating component and mention that such amplifiers are sensitive to thermal issues. The cost of repairs or replacements for the amplifier is also queried.
