Denon AVR-2308: Issues with Standby, Distorted Sound & Tweeter Burn - DSP Module Suspected
Andrzej Ł 2673 5
  • #1 16422046
    Andrzej Ł
    Help: 27
    Rate: 106
    If the volume level 1/3 starts with distraction and goes into standby. (Strong roar). If you reduce the significant volume you can start but a weak sound from the digital inputs, the powerful center distorted sine 16.6 kHz 20V pp is triggered on the center and surround outputs.
    Because of this, he burned the tweeters in the center.
    After the analogue (FM radio) normally plays.
    I suspect something with the DSP module. Voltage pre-checked, I am waiting for the service manual. Maybe someone knows this fault?
  • #2 16467706
    rimot
    Help: 145
    Rate: 146
    To start with SM
    Greetings.
    • Denon AVR-2308CI -AVR888-audio.pdf (13.38 MB) You must be logged in to download this attachment.
  • #3 16471942
    Andrzej Ł
    Help: 27
    Rate: 106
    Thank you, I have the service. A fault on the DSP module, either the soft or soft in the flash, I sent to the DENON service.
  • #4 16506700
    Andrzej Ł
    Help: 27
    Rate: 106
    The central service also could not do it, they said the same as I did that the DSP module was damaged, unfortunately not available anymore. However, I would like to try to fix it and therefore I am asking for a flash drive if someone has or could have it.
    Module designations: 2223852101 1U-3852
  • #5 16506740
    rimot
    Help: 145
    Rate: 146
    Somehow I do not want to believe that they do not have all the modules and all the more dunks. It's not that old equipment. Nice to me "service central "
  • #6 16587709
    Andrzej Ł
    Help: 27
    Rate: 106
    I repeat the request for a flash drive. Ein the whole module from disassembly.
