Connecting HD Audio Panel to AAFP on Asus H61M-K Motherboard: Using Headphones & Speakers
Vigot 21684 2
  • #1 17171654
    Vigot
    Rate: 14
    On the Asus H61M-K board I have pins described as AAFP (front panel connection). The question is, can I connect a panel with an HD Audio socket to AAFP? Can such a panel with HD Audio be easily connected to the AAFP and use the HD Audio jacks (headphones) while having the speakers connected to the audio output at the back of the computer?
    • Connecting HD Audio Panel to AAFP on Asus H61M-K Motherboard: Using Headphones & Speakers panel-front.jpg (142.97 KB) You must be logged in to download this attachment.
  • #2 17171705
    safbot1st
    Help: 2719
    Rate: 1585
    You have everything described clearly - well .. in English. English. Pinout supports both standards.
    You just need to switch the standard to HD Audio in the BIOS and connect the HD Audio plug.
    As for the headphones on FP, you also have 2 options: in the Realtek panel (yellow folder icon) - mute the audio output on the back, after plugging in the headphones at the front or playing "full" on both sides at once.
  • #3 17177068
    sylweksylwina
    Help: 1884
    Rate: 2357
    Connect normally and it will work. In UEFI, there is rather no option to switch to AC97.
    By default, the rear outputs will be muted when headphones are plugged in.
