Cleaning Process for Karcher 5.100 Vacuum Cleaner When Water Isn't Dispensing
grze29 38286 1
  • #1 16891528
    grze29
    A year ago, I used the Karcher 5.100 vacuum cleaner, now I turn it on and it goes on, when I turn on the laundry it buzzes as before but it does not give water. Has anyone described how to clean it? Please help.
  • #2 16893563
    petrol1
    Help: 7
    Rate: 73
    Check the power supply of the pump (tube), it may be cracked or blocked. Here you have a helpful link. https://youtu.be/ELJ1tVFpiIE
