Drop-down list - EXCEL Automatic field update after changing the list source
bigjeans 4395 10
  • #1 16897391
    bigjeans
    I need help with the dropdown in EXCEL namely ...
    How to do to update the position in the cell e.g. A2 after selecting from the drop-down list e.g. text: Cover 12.
    When I change the field "Cover 12" in the source of the drop-down list to eg Cover 14
    The problem is that I have to manually select and change A2 positions.
    I have a large warehouse that I added to the drop-down list and if I change anything, e.g. add a space or as in the example above, this item does not change automatically in the field where it was selected, the problem is that I have 2000 items that are already functioning and were selected from drop-down list and I would have to click a few hours in which I added a number or changed the name
    I wrote it a little chaotically ..
    Please help
  • #2 16897497
    JacekCz
    Help: 760
    Rate: 1462
    long ago you should have had a real database program
  • #3 16897602
    bigjeans
    Thanks for the comment, I just like Excel ;)
    I made a really good combine harvester and everything has been going on for a year, including the Warehouse, PZ, FV, PF, but this problem has been bothering me for some time. Besides, I am happy with what I have and for free.
    If you can help ..? then write about my question.
  • #4 16897809
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    bigjeans wrote:
    I have to manually select and change A2 items.
    Sample sheet attached
  • #5 16898350
    bigjeans
    I am sending a sample file.
    In the example, I have to click through position B4
    Please help
    • przykład.xlsx (10.54 KB) You must be logged in to download this attachment.
  • #6 16898391
    JRV
    Help: 805
    Rate: 455
    Macro only, customize. See 'warehouse' events
    • przyk.rar (15 KB) You must be logged in to download this attachment.
  • #7 16898420
    bigjeans
    Thank you for your answer
    I still have a question.
    I can see that VBA refers to sheet 1 as it is sequentially.
    And if I have several worksheets where there is a selection from the list and I would like the name to change in different columns in all of them?
    Is it doable?
    How to add more sheets to VBA? I'm not very good at this programming, but probably no other method?
  • #8 16898467
    JRV
    Help: 805
    Rate: 455
    instead of sheets (1), enter sheets ("Sales")
    u me not polish excel, VBA doesn't want signs etc.
    Added after 5 [minutes]:
    bigjeans wrote:
    i have several sheets
    add example, I don't have time to emulate
  • #9 16898516
    bigjeans
    I'm sending my combine ;)
    Please check if it can be done, practically in each of the sheets there is a selection of items from the list. and all items must be updated if I change something in the Warehouse.
    • Formularz4.rar (496.65 KB) You must be logged in to download this attachment.
    JRV
    Help: 805
    Rate: 455
    Everything can be done :)
    • Formularz41.rar (517.05 KB) You must be logged in to download this attachment.
  • #11 16898750
    bigjeans
    THANK YOU FOR YOUR HELP! :)
    That's what I meant !!! COOL
    greetings :)
    Added after 18 [hours] 47 [minutes]:
    Hello, I have a question because I have an error.
    Could this be because I have some sheets blocked? and then the function does not work?
    Below scr.
✨ The discussion revolves around the challenge of automatically updating cell values in Excel after modifying the source of a drop-down list. The user seeks a solution to ensure that when an item in the drop-down list (e.g., "Cover 12") is changed (e.g., to "Cover 14"), the corresponding cell (e.g., A2) updates automatically without manual intervention. Responses suggest using VBA macros to achieve this functionality across multiple worksheets. The user expresses a need for guidance on implementing VBA to update selections in various sheets and addresses issues related to locked sheets potentially causing errors in the function.
