Excel - Autocomplete / Prompt based on data from another sheet
kubajanic 7446 2
  • #1 16262052
    kubajanic
    Welcome,
    Is it possible to set (in one selected case) AutoComplete based on the indicated location?
    by default, autocomplete works on the data from the previous lines:
    ... by entering data into the spreadsheet, in the case of entering a new chord in the next line, the program checks whether there is a repetition in the same column (previous lines) and based on the entered characters, AutoComplete appears, which I can tap with Enter,
    I am looking for a method and I want the AutoComplete to be based on the data I give (the table I am indicating) then the program will read them from the indicated location, not from the lines above.
    example:
    In Sheet2 in cell A2 I write the letter "A", then I want the hint (Adam) to be highlighted based on the list of names I have provided in the table from Sheet1 A2: A7.
    • Autouzupelnianie.xlsx (9.93 KB) You must be logged in to download this attachment.
  • #2 16262318
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    Autocomplete is an autonomous mechanism and cannot be reprogrammed. In this case, only the drop-down list can be used, and once these names are entered, the next repeated entries can be obtained from the autocomplete.
