Quadcopter for Indoor/Outdoor Use, Stability, Speed, Payload: Syma X1/XC5 or DIY Drone Options
lor3mi44 3819 12
What quadcopter should I buy for indoor and outdoor use with good stability, precision, some speed, optional Sony webcam payload, and a budget of PLN 800–1000?
For this budget and use case, the thread recommends a Hubsan H501S X4 rather than a Syma, because it uses BLDC motors and offers headless mode, automatic return to base, follow-me, altitude/position hold, about 20 minutes of flight time, and up to 500 m range with video link [#16900377] If you want to carry a Sony camera, you should look at brushless-drive drones; brushed-motor models are said to be unable to lift a heavy payload and end up behaving like a "flying brick" [#16897960] The H501S was said to be around PLN 900 when ordered from abroad, while Polish shop prices were quoted much higher at about PLN 1299 or even PLN 1350–1600 [#16902180] [#16962021] [#16900525] The thread is generally negative about Syma drones, calling them weak on quality and missing newer safety features [#16900377]
  • #1 16897926
    lor3mi44
    For some time I have been deciding to buy a drone, but I don't know which one.
    I would like a quadrocopter, which is designed to fly both indoors and outdoors, its main features are to be stability and precision, and I would not despise speed. It would be great if it had a load capacity to mount a Sony webcam, but it's not a must. Mainly I would like to focus on something like not very advanced acrobatics.
    I never flew a drone anymore but I used to fly a helicopter and I was doing quite well.
    I was thinking about some Syma X1 or XC5.
    So, finally, could anyone recommend such a drone to me or tell me how to do it myself (I've never done it, but it's always a new challenge).
    best regards
    Edit:
    I forgot the price. I would like it not to exceed PLN 800-1000.
  • #2 16897960
    1 PAWEL
    Help: 674
    Rate: 1364
    Syma X8 Pro drone - look for descriptions for the beginning and for advanced users.
    If it is to support a Sony camera (what weight) it is rather a brushless drive.
    Most drones powered by brushed motors are not capable of
    lifting a heavy load acts like a flying brick.
  • #3 16900377
    Madrik
    Help: 627
    Rate: 1189
    I advise against Syma. One of the worst drones on the market. Quality aside, it lacks the safety features standard on newer drones. And when they add something, it works that you should pity God. Hence the low price of these drones.
    In the budget for PLN 800, I would rather recommend something from the Hubsana H501 family.
    For example, Hubsan H501S X4.
    The drone has BLDC motors, weighs less than half a kilogram.
    Range up to 500 meters, including video coverage.
    HD camera on board with 5.8 GHz transmitter.
    Transmitter with monitor.
    And most importantly - it has what Syma can dream of:
    - Headless mode.
    - Automatic return to base.
    - "follow me" function.
    - maintaining altitude and position.
    - Flight time 20 minutes.
    Record video on a memory card.
    You can choose the version with a compact controller, or a large - "professional".
    With delivery abroad, you can get around 900 PLN.
    Only semi-professional drones with a stabilized and guided gimbal would be better. But that's twice as high a budget.
  • #4 16900525
    1 PAWEL
    Help: 674
    Rate: 1364
    Price PLN 800 basic version of Hubsan H501S, for example on
    https://pl.aliexpress.com/item/Hubsan-H501S-X...nes-10CH-Brushless-With/32805908097.html?spm= a2g17.search0104.3.63.KoI9Aw & ws_ab_test = searchweb0_0, searchweb201602_4_10152_10065_10151_10344_10068_10345_10342_10343_51102_10340_10341_10609_10541_10084_10083_10304_10307_10301_10610_5060020_5870020_5130020_10312_10059_10313_10314_10534_5000020_100031_10604_10603_10103_10605_10594_10142_10107_5080020-10152, searchweb201603_25, ppcSwitch_3 & algo_expid = f765e57f-f3bb-426f-9e61-6d726a02b324-8 & algo_pvid = f765e57f-f3bb-426f-9e61-6d726a02b324 & rmStoreLevelAB = 5
    In Poland, Hubsan H501S is much more than PLN 1350-1600
  • #5 16902180
    Madrik
    Help: 627
    Rate: 1189
    Fortunately, you can order abroad and it will come.
    Pro version, in another popular portal on "B ....", about PLN 900 with shipment to Poland.
    I will not give the link because they disappear quickly.
    Everyone knows that bedspreads of 50-100% are the norm in our stores.
  • #6 16962021
    tolke83
    I found Hubsan in Poland for PLN 1299 (rcmplanet.eu), ordering with Ali is different. In Poland, I have a guarantee that I will receive the package within a few days and I know who I am buying from.
  • #8 16962305
    tolke83
    What about the service and complaint from Ali when the drone breaks? I know it's cheaper but somehow I have no conviction for Ali, the drone can work ok for a month or two and then fail, what about the warranty / return?
  • #9 16962327
    1 PAWEL
    Help: 674
    Rate: 1364
    There is a bit of a risk, but for 4 years I have not had a mishap with Ali's equipment.
    https://www.google.pl/search?num=100&newwindo...+serwisem+i+reklamacj%C4%85+z+Ali+&oq=A+co+z+ service + i + complaints% C4% 85 + z + Ali + & gs_l = psy-ab.12 ... 1945.1945.0.2668.1.1.0.0.0.0.128.128.0j1.1.0 .... 0 ... 1c .. 64.psy-ab..0.0.0 .... 0.h2FSFQl6144
    https://www.amazon.com/Hubsan-H501S-Brushless-Quadcopter-White/dp/B01BXY8E9K
  • #10 16962346
    tolke83
    Thanks for the info, but I'd rather spend more and have peace of mind about guarantees and refunds.
  • #11 17338015
    Pracus185
    Hey, now there are roughly as many brands and types of drones as there are mobile phones. I personally have good experiences with the Overmax drone. First of all, what I like about it is the simple and really intuitive controls ... you don't need to finish the plane pilot course to handle it here ;-) Unfortunately, some drones can be very cumbersome and clunky to use during the flight ...
  • #12 17338188
    1 PAWEL
    Help: 674
    Rate: 1364
    Wait a while for the brush motors to crash.
    Virtually all drones are easy to use.
    They only require a minimum of knowledge and practice :)
  • #13 17339144
    Madrik
    Help: 627
    Rate: 1189
    Drones are the easiest flying models to learn. They were created as working platforms and were supposed to hold the attached load stably - hence a very high degree of automation.
    In the drone, the pilot basically only sets the direction and in the cheaper ones, he also keeps an eye on the height. All the work. Anyone with average hand-eye coordination and minimal spatial imagination can handle it. Plus a little practice.
    We do not worry about stalling, turbulence, the influence of wind direction, stream detachment, slip vectors when turning, etc ...
    Unfortunately, in return, drones don't get half the fun of other flying models. Such boring dump trucks, like a toy car ... It just floats in the air.
✨ The discussion revolves around selecting a quadcopter suitable for both indoor and outdoor use, emphasizing stability, speed, and potential payload capacity for a Sony webcam. The Syma X1 and XC5 are initially considered, but several participants advise against Syma drones due to their poor quality and lack of modern safety features. Instead, the Hubsan H501S X4 is recommended as a better alternative, featuring brushless motors, a range of 500 meters, an HD camera, and advanced functionalities like headless mode and automatic return to base. The price for the Hubsan H501S is noted to be around PLN 800-1000 when ordered from abroad, although local prices may be higher. Concerns about warranty and service when purchasing from international sites like AliExpress are also raised, with some users preferring to pay more for local guarantees.
TL;DR: For PLN 800–1000, Hubsan H501S offers 20-minute flights and GPS safety; “I advise against Syma.” [Elektroda, Madrik, post #16900377]
Why it matters: This FAQ helps first-time pilots pick a stable indoor/outdoor quad, compare prices, and avoid weak payload setups.
What quadcopter best fits PLN 800–1000 for stable indoor/outdoor flying?
Forum consensus favors Hubsan H501S over Syma. It adds GPS position hold, headless mode, Return-to-Home, and Follow Me. Brushless motors boost stability and durability. You also get FPV with a built-in monitor. It balances learning indoors with confident outdoor range. [Elektroda, Madrik, post #16900377]
Is Syma X1/XC5 a good starter pick?
No. An experienced user warns: “I advise against Syma. One of the worst drones on the market.” The criticism cites poor quality and missing safety features common on newer models. Those omissions matter for beginners who need GPS hold and RTH. [Elektroda, Madrik, post #16900377]
Which safety features should I prioritize for first flights?
Prioritize GPS position/altitude hold, headless mode, and automatic Return-to-Home. These features stabilize hover, simplify orientation, and recover the craft if signal drops. Hubsan H501S includes all of them, making first flights more forgiving indoors and outdoors. [Elektroda, Madrik, post #16900377]
Can a quad carry a Sony webcam, or is that too heavy?
Use brushless (BLDC) motors if you plan to carry a small camera. A veteran notes brushed-motor drones struggle with payload and can “act like a flying brick.” For light cameras, BLDC platforms like H501S are safer choices. [Elektroda, 1 PAWEL, post #16897960]
How far and how long can Hubsan H501S fly?
Expect up to ~500 meters for control/video and about 20 minutes of airtime per pack. That endurance supports meaningful outdoor practice and simple follow-me shots. Always check local rules before pushing range. [Elektroda, Madrik, post #16900377]
What’s the price difference between buying abroad and locally?
One member reports ~PLN 800 for the basic H501S via AliExpress, versus PLN 1350–1600 at Polish retailers. The gap reflects common local markups. Budget for spares and an extra battery regardless of source. [Elektroda, 1 PAWEL, post #16900525]
Is ordering from AliExpress worth the risk versus local warranty?
There is some risk. Another pilot says he had no mishaps in four years ordering gear from Ali. How-To: 1) Check seller ratings and reviews. 2) Use tracked shipping and buyer protection. 3) Inspect on arrival and record unboxing. [Elektroda, 1 PAWEL, post #16962327]
Why do many warn against brushed‑motor drones like some Overmax models?
A seasoned user explains brushed motors wear quickly under load and can fail early. That raises crash risk and limits payload options. Quote: “Wait a while for the brush motors to crash.” Choose brushless for durability. [Elektroda, 1 PAWEL, post #17338188]
How hard is it to learn to fly a drone?
“Drones are the easiest flying models to learn.” Automation handles stabilization; you mainly set direction and watch altitude on basic units. Expect faster progress than with RC helicopters or planes. Practice still matters. [Elektroda, Madrik, post #17339144]
What does Headless Mode actually do?
Headless Mode fixes control orientation to the pilot, not the drone’s nose. Push forward and it goes away from you, regardless of yaw. It reduces orientation errors for beginners and helps in close quarters. [Elektroda, Madrik, post #16900377]
What is Return‑to‑Home (RTH), and when is it useful?
RTH commands the quad to navigate back to its takeoff point, typically on low battery or lost link. It preserves the aircraft when you lose sight or orientation. H501S includes automatic return to base. [Elektroda, Madrik, post #16900377]
Does Hubsan H501S record video and provide live FPV?
Yes. It records to a microSD on the aircraft and streams 5.8 GHz FPV to a controller with a built-in monitor. This lets you review footage while keeping a reliable live view. [Elektroda, Madrik, post #16900377]
Which controller versions exist for H501S?
You can choose a compact transmitter or a larger “professional” controller. Both support FPV monitoring; pick based on ergonomics and screen preference. Larger controllers suit outdoor gloves and longer sessions. [Elektroda, Madrik, post #16900377]
Is buying the H501S Pro version abroad realistic on a budget?
Yes. A member reports the Pro at about PLN 900 with international shipping on a large marketplace. Listings change, so search actively and confirm final price at checkout. [Elektroda, Madrik, post #16902180]
If I prefer local purchase, what prices should I expect?
Expect around PLN 1299 from a Polish seller cited in the thread. Local buying offers faster delivery and straightforward warranty handling, which some pilots value more than savings. [Elektroda, tolke83, post #16962021]
What’s an edge case that can ruin flights early on?
Adding a heavy camera to a brushed‑motor quad can overload it. Performance collapses, and handling feels like “a flying brick.” Use brushless platforms for any payload plans. [Elektroda, 1 PAWEL, post #16897960]
