New Computer Issue: Accessing Router Configuration Page 192.168.0.1 - Works on Phone
Gurred 40860 5
  • #1 16899510
    Gurred
    I have a problem getting to the router configuration page 192.168.0.1 on the computer Because it works on the phone the problem began after the computer was changed to a new one.
  • #2 16899526
    bubu1769
    Help: 1177
    Rate: 2374
    What router? What system on the computer?
  • #3 16899535
    KOCUREK1970
    Help: 3861
    Rate: 5489
    What are the network adapter settings in your computer and are you connecting to wifi or LAN?
  • #4 16899587
    Gurred
    Router ZTE MF283 + Operating system Windows 10 Home
    Is it connected over LAN and what do you mean by router settings?
  • #5 16899638
    KOCUREK1970
    Help: 3861
    Rate: 5489
    Gurred wrote:
    what do you mean by the router settings
    KOCUREK1970 wrote:
    What network adapter settings on your computer?
    I'm not asking for any router setting!
    Since you have reset the router, the network card in the computer has taken a completely different IP setting - and you have to correct it and the router login page will appear, then set the router as needed.
    Gurred wrote:
    192.168.0.1
    Does it have a router?
    So you need to set up the network card with this IP - 192.168.0.10
    Mask 255.255.255.0,
    DNS blank
  • #6 16899655
    Ricoh_220
    Help: 464
    Rate: 754
    Is dhcp enabled in the computer?
    Whether this router definitely has a configuration page 192.168.0.1 I sometimes saw 192.168.1.1
    it's worth checking.
    If dhcp active, see how you get the address. The gateway address is the router's address and should be used for configuration.
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
