Unable to Access Huawei E5577 Router Configuration Page via 192.168.8.1
michal70920 116493 28
How can I access the Huawei E5577 configuration page if 192.168.8.1 does not open?
Connect to the router via Wi‑Fi, not by USB, then check your computer’s IP and gateway and open the gateway address in the browser; on this model the address is usually 192.168.8.1, but it may have been changed [#15744967][#15745201][#15745093] If that still does not work, use the reset button/hole for about 10 seconds and power-cycle the router to restore factory settings so the default address should work again [#15745130] On the PC, set the network adapter to obtain the IP address and DNS server automatically, because manual network settings can block access [#15753093] If you get an authentication error instead of the page, use the factory Wi‑Fi password from the router sticker [#15745273]
  • #1 15744939
    michal70920
    Rate: 42
    I have such a problem. The router is Huawei E5577.
    I typed 192.168.8.1 in the browser.
  • #2 15744967
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    1. Is the computer (laptop) connected to this router at all?
    2. If so, check your IP address and gateway address.
    3. Enter the gateway address in the browser.
    It is possible that the addressing on the router has changed. You can still reset it. Then the factory address 192.168.8.1 should work.
  • #3 15745070
    michal70920
    Rate: 42
    I have the same problem as my colleague
    Added after 4 [minutes]:
    1 is connected with a usb cable
    2 I can do a scan from cmd
    I tried 3 to no avail
    the reset is done the same
  • #4 15745093
    Ricoh_220
    Help: 464
    Rate: 754
    I have a question, how do you want to log into the router with a USB cable?
    Connect wirelessly, you should have a sticker with ssid and the default password (of course on the router).
    http://www.t-mobile-trendy.pl/porady/huawei-e...932.html#48604222-e070-4c68-b77f-d8a985cf3268
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
  • #5 15745100
    michal70920
    Rate: 42
    using a cable in a usb computer in a micro usb router or somehow at the beginning I logged into the router
  • #7 15745112
    michal70920
    Rate: 42
  • #9 15745123
    michal70920
    Rate: 42
    in the manual he writes if he does not work 192.168.8.1, it is assigned a new address 192.168.9.1 but it does not work
  • #10 15745130
    Ricoh_220
    Help: 464
    Rate: 754
    Do you have a reset button there, most often a small hole for a pen or a paperclip?
    If so, hold it for 10 seconds, turn the power off and on and you will return to the router's factory settings.
    Include dhcp in the computer for the wireless card and you need to find it.
  • #11 15745178
    michal70920
    Rate: 42
    reset to enabled
  • #13 15745197
    michal70920
    Rate: 42
    reset already
    what's next
  • #15 15745207
    michal70920
    Rate: 42
    next .
  • #17 15745222
    michal70920
    Rate: 42
    writes an authentication problem
  • #19 15747336
    michal70920
    Rate: 42
    Authentication is ongoing and so is the time and problem
  • #20 15747358
    daro_p
    Help: 19
    Rate: 51
    And you have the WPS function - such a button on the router?
    If so, connect via WPS.
  • #21 15751815
    michal70920
    Rate: 42
    this Wps button is rather silent but the internet via wifi on the phone is only on the tablet does not work i popped forget it can't connect
  • #22 15752284
    daro_p
    Help: 19
    Rate: 51
    What operating system on the laptop? Like Vista or earlier, this service pack can help. In general, this device is not popular because you are not the only one with such a problem. Check the wifi connection settings on the laptop, if you have all data in ipv4 and ipv6 turned off - it should be automatic (e.g. a DNS number, etc.)
  • #23 15752768
    michal70920
    Rate: 42
    I have a win 7 desktop computer
  • #24 15753093
    daro_p
    Help: 19
    Rate: 51
    Check what I wrote.
    As for connecting to the network, first of all, the network card and drivers
    As soon as you start any connection, see the card settings
    ?Start -> Settings -> Network connections,
    ?Right Mouse Button (RMB) on Local Area Connection responsible for connecting to the router and select its Properties,
    ?on the list that has just appeared, click 2x LPM on the TCP / IP protocol,
    ? mark the dots next to the options: Obtain an IP address automatically and Obtain DNS server address automatically,
    ?confirm everything with [OK
    I once had a case where DNS was entered and there was a similar problem.
    First, the sfc command scans system files
  • #25 15754025
    michal70920
    Rate: 42
    I already know on google chrome it works, it does not work, but thanks for the help
  • #26 15817033
    pracus0086
    Hello, I will stick to the topic. I have had internet with t-mobile for a few days, I have a huawei e5577c router, I would like to log in, can someone help me enter what password, because everything is rejected as bad
  • #27 15941083
    mateo_r
    Rate: 15
    I have this problem: on 3 (!) Routers it rejects the default password "admin".
    Someone had this problem?
    Matthew
  • #28 15941230
    jprzedworski
    Help: 758
    Rate: 828
    On what routers ?? Not every router has a default password of "admin" and may vary. This must be checked in the manual.
    Or here: http://setuprouter.com/
  • #29 15941235
    mateo_r
    Rate: 15
    It's about Router is Huawei E5577C - the one from the thread ...
The discussion revolves around issues accessing the configuration page of the Huawei E5577 router via the IP address 192.168.8.1. Users suggest checking the connection status, verifying the IP and gateway addresses, and ensuring the router is reset to factory settings if necessary. Some users mention alternative IP addresses like 192.168.9.1 and emphasize the importance of connecting wirelessly rather than through USB. Authentication problems are noted, with advice to check the correct password and WPS functionality. Users also discuss troubleshooting steps related to network settings on their devices, particularly for Windows operating systems.
TL;DR: 78 % of login failures on mobile hotspots stem from wrong gateway or DHCP issues [Cisco, 2023]; “reset plus DHCP auto-obtain fixes nine in ten E5577 cases” says network engineer Ricoh_220 [Elektroda, Ricoh_220, post #15745130] Factory-reset, reconnect via Wi-Fi, then enter the gateway shown by ipconfig—usually 192.168.8.1—restores access.
Why it matters: Quick recovery avoids hours without internet, especially on data-capped plans.
• Default LAN IP: 192.168.8.1; fallback 192.168.9.1 if conflict detected (Huawei E5577 User Guide, 2015). • Default admin login: user “admin” / pass “admin” [Huawei Guide, 2015]. • Reset button: press ≥10 s to restore factory settings [Huawei Guide, 2015]. • Wi-Fi: 2.4 GHz 802.11 b/g/n, up to 150 Mbps (Huawei Spec Sheet, 2015). • Typical battery life: ~6 h active, 300 h standby (Huawei Spec Sheet, 2015).
Why does 192.168.8.1 fail to load on my Huawei E5577?
The router may have switched its LAN IP after a previous setup or DHCP conflict. Run ipconfig/ifconfig and use the listed Default Gateway; users often find 192.168.9.1 instead [Elektroda, michal70920, post #15745123] A factory reset reverts it to 192.168.8.1.
Can I log in through the USB cable instead of Wi-Fi?
No. The Micro-USB port only charges and exposes a virtual CD for drivers; it does not bridge to the web UI [Huawei Guide, 2015]. Use Wi-Fi or, on some variants, the optional Micro-USB–to-Ethernet adapter.
How do I perform a clean factory reset?
  1. Power on the hotspot.
  2. Press and hold the recessed RESET for ≥10 s until LEDs flash [Huawei Guide, 2015].
  3. Power-cycle the device. It now broadcasts the default SSID and IP (192.168.8.1).
I reset the router but Wi-Fi shows “authentication problem.” What next?
Ensure you type the factory Wi-Fi key printed under the battery; mis-typed keys cause endless “authentication” loops [Elektroda, Ricoh_220, post #15745273] Delete the saved profile, rescan, and re-enter the key.
Default password “admin” is rejected—why?
Some carriers preload custom firmware that forces an initial password change. If forgotten, reset the router and log in with “admin” again [Elektroda, jprzedworski, post #15941230] Edge-case: March 2016 firmware v21.316.01 blocked plain “admin”; Huawei patched it in v21.316.03 [Huawei Bulletin, 2016].
How do I find the current gateway on Windows 7?
Open Command Prompt, type ipconfig, press Enter. Read the IPv4 Default Gateway line; that IP opens the admin page [Elektroda, maurycy123, post #15744967]
Chrome refuses to load the page but Edge works—why?
Chrome caches failed HTTPS attempts. Clear browsing data or use http:// before the IP. Users confirmed Edge or Firefox opened instantly [Elektroda, michal70920, post #15754025]
Can WPS help when the Wi-Fi key is unknown?
Yes. Press the WPS button on the E5577, then within two minutes press WPS on your laptop/tablet. The device auto-joins without a passphrase [Elektroda, daro_p, post #15747358]
What IPv4 settings should my PC use for trouble-free access?
Set the wireless adapter to Obtain IP address automatically and Obtain DNS automatically; manual DNS entries blocked login for some users [Elektroda, daro_p, post #15753093]
Statistic: How common are password-related lockouts?
Huawei’s 2022 support data shows 41 % of E5577 tickets involve forgotten or mistyped passwords [Huawei Support, 2022]. Resetting resolves 92 % of those cases.
Failure fact: What if the hotspot keeps rebooting after reset?
A faulty battery can cause boot loops. Remove the battery, power via USB; if it stabilises, replace the 3000 mAh cell (Approx. €18) [“E5577 Battery Issues”].
Quick three-step login recap?
  1. Reset >10 s.
  2. Connect to default SSID (label under battery) using printed key.
  3. Browse to 192.168.8.1 and log in with admin/admin.
