Access ZTE MF283+ Router Configuration Page: 192.168.0.1, Default Gateway, IPconfig Issues
Gurred 11394 5
  • #1 16832068
    Gurred
    I have a problem getting into the configuration page of my ZTE MF283 + router. I changed my computer, and access to page 192.168.0.1 is unreachable with this procedure. I used to enter the old computer normally. After entering ipconfig, the default gateway is 192.168.0.1
  • #2 16832086
    jimasek
    Help: 3783
    Rate: 2681
    Do you enter http: // before the address? Have you checked on another browser?
  • #3 16835554
    Gurred
    So I typed from http: // and on another browser and then the same.
  • #4 16837766
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @Gurred
    What IP does the router have by default, you have set up the network card for this operation? (you entered the appropriate parameters there).
  • #5 16838017
    Gurred
    KOCUREK1970 wrote:
    @Gurred
    The IP on the router is 192.168.0.1 (it is written under it) and what treatment do you mean?
  • #6 16838040
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Configure the network card in your computer (give it address 192.168.0.10).
