Audi A3 8P 1.9 TDI: Sudden Left Low Beam Issue - Bulb OK & Fuse Not Found (No Tools)
kam250 7845 2
  • #1 16900060
    kam250
    Rate: 26
    Hello, the problem appeared suddenly and I am looking for a quick solution, so suddenly the left low beam is missing, the bulb is ok, I was looking for a fuse but it is probably not there, I will add that at the moment I can only do without tools.
  • #2 16903407
    Gunslinger
    Level 30  
    Help: 114
    Rate: 461
    It is possible that the handle contacts are burned out. Do you have diagonal light from the back?
  • #3 16911793
    kam250
    Rate: 26
    Hello. The topic is solved, the pin in the plug inside the lamp was to blame. Kisses
