[Solved] Audi A4 B6 2002, 1.9 TDI, 130km - Left Dipped Headlight Issue: Bulbs Burning Out & Diagnosis
netvlc 16503 6
  • #1 17229965
    netvlc
    Hello, I have a problem with the left headlight (low beam) in AUDI A4 B6 2002. 1.9 TDI 130 km, namely after replacing a burnt bulb, the headlight stopped working on the same day (after about 10 minutes of driving after replacement). I bought a new bulb and it didn't work from the start (it burned out right away). I would like to add that I checked the bulbs and both were operational before connecting them to the car, but after trying to turn on the lights, they burned out (but there is no sign of burnout). I measured the voltage on the wires supplying the voltage to the bulb and it was over 12 V. To sum up - the voltage is there, but the bulbs burn out, so I suspect a short circuit, but I have no idea where to look for it. I would like to add that there are no dipped beam fuses and the right headlight is working all the time. Please help.
    Edit: May 19, 2018 22:03 I forgot to add that I checked the car's computer with the torque + ELM 327 application and it showed no errors.
  • #2 17230035
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    This I understand the usual H4 or H7?
    netvlc wrote:
    I measured the voltage on the wires supplying the voltage to the bulb and it was over 12 volts
    How much exactly and in what state of engine operation?
    netvlc wrote:
    In conclusion - the voltage is there, but the bulbs burn out,
    So either the voltage is too high or the bulbs you assume are some crap.
    netvlc wrote:
    therefore I suspect a short circuit, but I have no idea where to look for it.
    Why a short circuit? If the voltage is too high, first of all, a suspicious voltage regulator that has already killed the battery. Other possible causes are loose battery clamps, with the battery disconnected, the alternator voltage regulator has the right to "freak out" ...
    netvlc wrote:
    but after trying to turn on the lights, they burned out (but you can't see any sign of burnout)
    Checked with an ohmmeter - have a break?
  • #3 17230048
    netvlc
    The bulbs are H7, the voltage on the wires was 12.3 V after turning the key in the ignition switch, the burned bulbs were checked with a multimeter - there is a break and by connecting the 12 V power supply to them from the screwdriver battery (the bulbs did not light up). The battery terminals are not loose.
  • #4 17230065
    jdubowski
    Help: 2511
    Rate: 2804
    netvlc wrote:
    Bulbs are H7
    No-name or some "normal" company?
    12.3V with the engine running is not enough (but too low voltage does not make the life of the bulbs shorter). If the measurement was with the engine not running, the engine must be started and the measurement repeated.
  • #5 17230078
    netvlc
    "Normal" bulbs, additionally checked earlier in another car and they were ok. Measurement made with the engine not running.
    robin161
    Help: 74
    Rate: 276
    Check carefully the cube / plug of the bulb if it is not overheated (if so, change to ceramic).
    In addition, to check the cables for a short circuit, whether any of them are not frayed, or if necessary. with cracked insulation.
  • #7 17231011
    netvlc
    Hello again, so far the problem has been solved. I cleaned the cube thoroughly, which was attached to the bulb, and did not push it too hard. I'm not sure what caused the breakdown of the previous bulbs, but it turns out that it was related to this cube. Thanks to everyone for your help.
The discussion revolves around a left dipped headlight issue in a 2002 Audi A4 B6 1.9 TDI, where the user experienced repeated bulb failures shortly after replacement. Initial troubleshooting included checking the voltage at the bulb socket, which measured over 12 V, and confirming the bulbs were functional prior to installation. Suggestions from other users included examining the bulb socket for overheating and inspecting wiring for shorts or frayed insulation. The user ultimately resolved the issue by cleaning the bulb connector, indicating that the previous bulb failures were likely related to this connection.
