TP-Link Authorized Service Centers in Poland: Fast Router Repair Support & Locations
.:aspire:. 9348 19
Where can I send a TP-Link router in Poland for warranty service or replacement?
You generally cannot send a TP-Link router to an authorized repair center in Poland, because TP-Link does not repair its equipment and instead replaces it when it is actually damaged and under warranty [#16903635] TP-Link’s Polish support says a damaged, complete product — device, antennas, and power supply if included — should be delivered to the place of purchase together with the fiscal receipt or VAT invoice [#16902368] The official support/RMA page and contact page are the places to check for the current procedure [#16902368] So the practical route is to return it to the seller, not to look for a separate local TP-Link service center [#16903635]
  • #1 16902191
    .:aspire:.
    Help: 53
    Rate: 62
    Hi. What authorized service in Poland supports TP-Link routers?
    I was looking on the net, I didn't find a point where I could send for repair. I know I can return the router where I bought it, but I think sending it directly to an authorized service center will speed up the process.
  • #3 16902371
    KOCUREK1970
    Help: 3869
    Rate: 5505
    .:aspire:. wrote:
    i think sending directly to an authorized service will speed up the process.
    You can return it to the store (complaint) and request replacement of the equipment - the complaint is much more favorable (for the customer) than the warranty.
  • #4 16902385
    dt1
    Admin of Computers group
    Help: 7329
    Rate: 8317
    You can demand anything, but the store does not have to agree to it (Art 560 of the Civil Code, if I remember correctly).
    KOCUREK1970 wrote:
    a complaint is much more advantageous (for the customer) than the warranty.
    It must be a warranty. It is not always better. For example, the manufacturer can provide a 3-year warranty (and this is the case with current TPLink products), and the warranty can only be used for 2 years.
    There is one more interesting point:
    uokik.gov.pl wrote:
    For one year of the seller's liability, there is a presumption that the defect or its cause existed at the time of sale. This situation makes it easier to file a complaint, because it is the entrepreneur who has to prove that the defect was caused by the fault of the consumer.
    If the defect is noticed at a later date, i.e. between the 12th and 24th month from the release of the goods, the consumer should prove that the defect of the goods existed at the time of purchase - e.g. it is the result of the use of poor-quality materials, incorrect production or incorrect manual or maintenance. In support of its claims, it may (but does not have to) use the help of specialists, including the opinions and analyzes of independent experts.
    So if the router is at least one year old, then its current owner will be obliged to prove that the defect existed at the time of purchase (which in my opinion could be difficult and even quite expensive, if feasible, if you find an interesting seller - here warranty can sometimes be easier to fulfill).
  • #5 16902403
    KOCUREK1970
    Help: 3869
    Rate: 5505
    Here, the Consumer Act of December 25, 2014 plays the main role.
    The replacement for a new and defect-free one is listed as the first in the Consumer Act (resulting from the provisions on complaints) - and the customer has the right to demand it, referring to its provisions.
    If the customer's request (replacement for a new and defect-free item) cannot be met, the store is obliged to propose a different solution to which the customer is NOT obliged or forced to agree and can still insist.
    It is the customer who indicates what he expects from the seller (replacement with new and defect-free goods, price reduction, repair).
    It is better to use the determination of non-compliance of the goods with the contract.
    It is more favorable in the first 2 years :) (when it comes to the manufacturer's warranty for a period of 3 years).
    For the first 2 years, it is protected by the Consumer Act and the provisions of the Civil Code.
    When using the warranty, you have virtually no rights and you are forced to agree to the manufacturer's conditions.
    I have not heard of a coincidence that the store rejected the customer's request and demanded to prove that it was to blame for damaged equipment over 12 months.
    The manufacturer's service will replace it just like that and will not examine the equipment in depth - if it gets there, they will check the cause of the damage and it may be uninteresting then?
    Very often, the seller does not give the equipment to check anywhere, just exchanges the customer and that's it - then he reports the pre-sale damage to the manufacturer of the equipment and the manufacturer replaces it with the store immediately for a defect-free item.
    I have used complaints many times (and practically only from it), the provisions of the Consumer Act have never failed me (maybe once, but the store heard that I was going to the Consumer Ombudsman and immediately changed its previous negative position :D ).
  • Consumer law limits replacement demands for repaired routers
    #6 16903051
    dt1
    Help: 7329
    Rate: 8317
    I propose to consider http://prawo.sejm.gov.pl/isap.nsf/DocDetails.xsp?id=WDU20170000683 - a few things have changed since 2014.
    Of course, he can, I wrote that he can demand everything, but we have the aforementioned Art 560 § 2. If the buyer is a consumer, he may, instead of the seller's proposed removal of the defect, demand that the item be replaced with a defect-free one or, instead of replacing the item, demand that the defect be removed, unless it is impossible to bring the goods into conformity with the contract in the manner chosen by the buyer or would require excessive costs compared to the method proposed by the seller.
    The seller can easily prove that a post-repair, used router in an open package will have a lower value than a new, wrapped one, so if the customer is to give the customer a new one off the shelf and replace it with a post-repair / used condition - a replacement request will incur excessive costs compared to repair by the manufacturer's service.
    In the case of TPL, it may be, but it is not always better. Door-to-door guarantees, in which the service is declared within a reasonable time, on-site guarantees (e.g. next-business-day) are in my opinion more favorable than warranty claims :)
    You see, and you can meet, because there is such a record and I didn't make it up. Only that, fortunately, the store usually does not see a problem when it comes to handling the complaint, so this usually does not happen.
    I also used the services of the Ombudsman, she has a lot of knowledge, but unfortunately little possibilities. And for items of lower value, rarely any consumer will bring an action in court - and a dishonest seller can rely on it. The Ombudsman himself can only threaten, he can write a nice letter full of relevant paragraphs and he can assist the client in referring the case to the Court. Unfortunately, it cannot force the seller to do anything (as I have already found out as a customer of a dishonest company - only the notification that the case was referred to the Court affected them).
  • #7 16903632
    .:aspire:.
    Help: 53
    Rate: 62
    Thank you very much for legal advice, but I know consumer rights. I just wanted to ask if anyone knows which ASP is supported by TP-Link.
    TP-Link's technical consultant said to return it to the seller, that is: either they send it to some foreign service, or the seller sends it to some hub that does expert opinions or exchanges.
    jimasek
    Help: 3783
    Rate: 2683
    If the router is damaged, you give / send back to the place of purchase. There are no authorized services, because TP-link does not repair its equipment, but only replaces them if they are actually damaged and under warranty.
  • #9 16903662
    .:aspire:.
    Help: 53
    Rate: 62
    OKAY. Thanks. The helpline technician spread his hands and said the router was damaged. I bought it 2 weeks ago so there shouldn't be (hopefully) problems with the replacement.
  • #10 16903679
    jimasek
    Help: 3783
    Rate: 2683
    It is a pity that you did not write what the device model is, what connection and what is going on ??? Unfortunately, we are not fairies.
    Much said that "technician" :)
  • Wi-fi association fails intermittently despite visible ssid
    #11 16903713
    .:aspire:.
    Help: 53
    Rate: 62
    I don't know who he was there. In any case, the fault is that you cannot connect to the Wi-Fi network every few hours. After restart, everything is OK, and after some time the problem returns again. Internet via LAN works perfectly all the time, there are problems with Wi-Fi. The network is visible all the time, but you cannot connect to it (by any device in the house). As part of the test, I turned off all security and combined with DHCP. The same problem all the time.
  • #12 16903918
    jimasek
    Help: 3783
    Rate: 2683
    What is this internet when connected to the TP-link? The model of this router?
  • #13 16903939
    .:aspire:.
    Help: 53
    Rate: 62
    Neostrada. TP-Link TD-W8970. The cable is plugged into the ADSL connector.
    Internet via LAN is still available. Sometimes you cannot connect to Wi-Fi.
  • #14 16903956
    jimasek
    Help: 3783
    Rate: 2683
    How are your Wifi configured? Turn off all machines, set a specific channel and width to 20MHz, How are Wireless Security set up? Test 802.11g how does the wifi network behave?
  • #15 16903969
    .:aspire:.
    Help: 53
    Rate: 62
    I have already done so, additionally tested with disabled security. Now I only have mac filtering. And then the same problem.
    Sometimes it throws "authentication error" on the device it wants to connect.
  • #16 16908477
    jimasek
    Help: 3783
    Rate: 2683
    Show what you have set in Wireless Settings and Security. Enables WPA2 / AES security,
  • #17 16911704
    .:aspire:.
    Help: 53
    Rate: 62
    My security is off. Only macros filtering works.
    It's the radio's 100% fault.
  • #18 16911708
    jimasek
    Help: 3783
    Rate: 2683
    Well, you say so, it remains to be returned to the store and a complaint.
  • #19 16911767
    .:aspire:.
    Help: 53
    Rate: 62
    I know. That's why I asked which ASP TP-Link supports. It looks like I have to send the dish back to the seller and the dish is processed for a month or more.
  • #20 16912101
    jimasek
    Help: 3783
    Rate: 2683
    Unfortunately, we won't fix it on the forum. This is the policy of the TP-Link corporation.
Inquiries regarding authorized service centers for TP-Link routers in Poland reveal that TP-Link does not have dedicated repair services; instead, they typically replace defective units under warranty. Users are advised to return faulty routers to the place of purchase for replacement. The discussion also touches on consumer rights related to warranty claims, emphasizing the importance of understanding the Consumer Act and warranty terms. A specific case involving a TP-Link TD-W8970 router experiencing intermittent Wi-Fi connectivity issues was also discussed, with suggestions for troubleshooting and configuration adjustments.
TL;DR: In Poland, TP‑Link routers typically have a 3‑year manufacturer warranty, and “the manufacturer can provide a 3‑year warranty.” Start claims via the seller; authorized walk‑in service points aren’t used. [Elektroda, dt1, post #16902385] Why it matters: This FAQ shows exactly how to get your TP‑Link router repaired or replaced fast, and what rights or steps apply in Poland, especially if Wi‑Fi fails.
Is there an authorized TP‑Link service center in Poland I can ship to directly?
No. TP‑Link handles warranty through the place of purchase. The brand’s policy is exchange-based, not walk‑in repairs. Return the router to your seller to open a claim. “TP‑Link does not repair its equipment, but only replaces them.” [Elektroda, jimasek, post #16903635]
How do I start a TP‑Link warranty claim (RMA) in Poland?
Bring the complete product to the seller: router, detachable antennas, and the original power supply. Include a receipt or VAT invoice. Ask the seller to process the claim under warranty. Many retailers forward units to TP‑Link’s hub for assessment or exchange. [Elektroda, dt1, post #16902368]
Which is faster: a store complaint or the manufacturer’s warranty?
It depends. A warranty may promise convenient handling, while a complaint can seek replacement, price reduction, or repair. However, the seller can refuse replacement if it imposes excessive cost and opt for repair. This follows Civil Code Art. 560 §2. [Elektroda, dt1, post #16903051]
What does the 12‑month presumption mean for my router complaint?
During the first 12 months after purchase, the law presumes the defect existed at sale. This helps the consumer. From months 12 to 24, you must show the defect existed at purchase, for example via expert opinion. Plan evidence accordingly if your unit is older than a year. [Elektroda, dt1, post #16902385]
Can I demand a brand‑new replacement instead of repair?
You can request replacement, but the seller may choose repair if replacement creates excessive cost compared with repair. Courts allow this balance under Art. 560 §2. Expect replacement to be denied when a repair restores conformity at lower cost. [Elektroda, dt1, post #16903051]
Does TP‑Link repair routers, or do they exchange them?
Policy: exchange rather than repair. Units confirmed faulty under warranty are typically swapped. There are no Poland‑based, consumer‑facing authorized service shops for bench repair. “TP‑Link does not repair its equipment, but only replaces them.” [Elektroda, jimasek, post #16903635]
What must I include when returning my router for service?
Provide the complete set: device, detachable antennas, and the original power supply if it came with the product. Attach proof of purchase (receipt or VAT invoice). Incomplete submissions can delay handling or lead to rejection. [Elektroda, dt1, post #16902368]
How long does a TP‑Link claim take in Poland?
User reports suggest about a month when processed through the seller. Timelines vary by retailer logistics and stock availability for exchange. Ask your store for their stated SLA so you can plan connectivity during the wait. [Elektroda, .:aspire:., post #16911767]
My Wi‑Fi disconnects or won’t authenticate on TD‑W8970—what should I try first?
Test a clean 2.4 GHz setup: disable band steering, set a fixed channel, and force 20 MHz channel width. Temporarily limit mode to 802.11g to rule out compatibility issues. If LAN stays stable but Wi‑Fi fails after hours, proceed with a claim. [Elektroda, jimasek, post #16903956]
What is an RMA in this context?
RMA means Return Merchandise Authorization. For TP‑Link Poland, you trigger it via the seller by returning the complete product with proof of purchase. The seller coordinates with TP‑Link’s support workflow for diagnosis or exchange. [Elektroda, dt1, post #16902368]
I bought my router two weeks ago—what’s my best next step?
Return it to the seller with your receipt and full accessories. Ask to open a warranty claim immediately. Early in ownership, retailers often handle logistics quickly because the product is near‑new and under full warranty. [Elektroda, jimasek, post #16903635]
Do TP‑Link routers in Poland really have a 3‑year warranty?
Yes, current models were noted with a 3‑year manufacturer warranty in the discussion. This exceeds the 2‑year statutory seller liability period and can help after month 24. Verify your model’s card for exact terms. [Elektroda, dt1, post #16902385]
What if the store stonewalls or refuses my request?
Escalate formally and consider the Consumer Ombudsman. The Ombudsman offers guidance and letters but cannot force action. Persistent sellers often respond once court action is signaled. Keep records of all communications and timelines. [Elektroda, dt1, post #16903051]
Any edge cases I should know before filing a complaint?
After 12 months, you must prove the defect existed at purchase, which can require expert analysis and added cost. This shifts the burden from the seller to you. If that is impractical, a manufacturer warranty claim may be simpler. [Elektroda, dt1, post #16902385]
How should I package the router for return to avoid delays?
Include everything: router, antennas, original power supply, and your receipt or VAT invoice. Pack securely to prevent transit damage. Missing accessories can stall processing or trigger rejection until you supply the full set. [Elektroda, dt1, post #16902368]
Can a manufacturer warranty be more convenient than a store complaint?
Sometimes yes. A warranty can offer door‑to‑door or faster service promises, while complaints follow statutory paths and cost‑balance rules. As one expert noted, guarantees can be “more favorable” than complaints in some cases. [Elektroda, dt1, post #16903051]
