Choosing a New Router for Neostrada: TP-Link TD-W8951ND Replacement Options (100-150zł)
Wisniowa 3507 3
  • #1 16435475
    Wisniowa
    My current TP-Link TD-W8951ND router has recently died for a few days. An Orange technician came and revived him somehow, but he recommended buying a new one because the current one can fall on the amen at any time (at the top it is quite yellowed).
    From experience, he found that the company's products from the range of up to PLN 100 have an average lifetime of 2 years, and I will hit so much on holidays.
    I wish his successor was not worse. At least the same parameters, better welcome. Here its specifications;
    http://www.ceneo.pl/11055030#tab=spec
    I care about good WiFi coverage, durability, stability of operation, safety and of course trouble-free operation of the neostrada.
    The service technician advised against TP-Links and recommended D-Link, maybe something can be proposed from them? I do not reject TP-L in advance, but I am not particularly attracted to them.
    Lease from Orange is not an option, I want to remain independent. I am asking you for some specific suggestions, reliable and proven. I will be grateful for your help.
    Regards.
  • #2 16435484
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    The power supplies in TP-Link routers are damaged (the electrolytic capacitors dry out).
    Just buy a new power supply and they work without any problems.
  • #3 16435723
    LucekB
    Help: 143
    Rate: 137
    I recommend TD-W8960N, I usually mount them on clients.
    Asusy NP are also good: Asus DSL-N14U
  • #4 16438107
    punkwsieci
    Rate: 73
    I recommend some asus, in your budget you have e.g. DSL-N12E
