Silvercrest Turntable in Lidl - Worth it? Home Use, Ruby Needle, Compatibility with Phono Preamps
Tosca 7941 3
  • Questions about SilverCrest turntable cartridge and phono preamp compatibility
    #1 16903719
    Tosca
    Rate: 18
    Hi, from tomorrow in lidlu SilverCrest turntables are to appear.
    Unfortunately, I can not find additional data or opinions about this turntable. And I have a few questions
    Is it worth using for this price at home?
    It is written that it has a ruby needle. What will it be for the type of inserts?
    I have an amplifier with a phono preamplifier, currently Technics SU-810. But I also have models from other manufacturers that support eg MC cartridges or only MM. Or maybe this turntable already has a preamplifier in it?
    I can not find the full specification anywhere.
    Well, it has a three-year warranty, so probably it will not be a total sell.
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    Read:
    https://www.winyl.net/viewtopic.php?t=428&start=120
    For two and a half hundred words, you can do something meaningful:
    https://www.youtube.com/watch?v=xiIWx5G7VH8&ab_channel=ReduktorSzumu
    An example alternative (in this price range):
    http://john.ccac.rwth-aachen.de:8000/telefunken/rs100/index.html
  • #3 16903856
    MDD
    Help: 179
    Rate: 545
    Do not even touch it.
  • #4 16905327
    Tosca
    Rate: 18
    Ok, so the decision is taken. I'm not buying.
    Thank you and best regards
