60 Seconds Game Issue: Black Screen with Sound on Windows 7, Nvidia GeForce G102M Laptop
dus1eek 27615 10
Why does 60 Seconds show a black screen after the menu appears while the sound keeps playing on Windows 7 with an Nvidia GeForce G102M laptop, and how can I fix it?
Install DirectX 9 and delete the game's `Settings.dat` configuration file; after that, the game should open normally again [#16909366][#16910328] The file is typically in `C:\Users\[YourUserName]\AppData\LocalLow\Robot Gentleman Studios\60 Seconds\Settings.dat`, and game settings are usually stored there regardless of whether the game itself is installed on C: or D: [#16909366][#16910052][#16910208]
  • #1 16908749
    dus1eek
    Hello, I didn't know where to put this post, but because I have a laptop, I put it here.
    Recently I purchased a game called "60 seconds". When the game starts it's OK, but when the menu for that game should appear, something like this happens - the game menu appears for literally 2-3 seconds, then disappears and there is a black screen, but the sound of the game can be heard. I updated the graphics card and monitor drivers, but it didn't help :( Please help, my system is Windows 7, video card is nvidia GeForce G102M, laptop monitor. I don't know what this problem might be caused by. Thank you in advance for your help.
  • #2 16908995
    silentyt
    Rate: 42
    You can exact specifications
  • #3 16909062
    dus1eek
    Windows 7;
    Nvidia GeForce G102M;
    Intel Pentium Inside;
    2GB of RAM;
    Unfortunately, I don't know any more. :(
  • #4 16909098
    safbot1st
    Help: 2719
    Rate: 1585
    Other games work ok?
    Post the error from the event log if it is from this event.
    Check if there is an image on the external monitor.
  • #5 16909323
    dus1eek
    That's how the rest of the games work OK. How to check if there is an image on the external monitor? Because I have a laptop monitor.
  • #6 16909349
    daminek1234
    Help: 61
    Rate: 88
    @ dus1eek you connect the laptop with a VGA cable to the monitor.
  • #7 16909366
    silentyt
    Rate: 42
    No exaggeration, you don't need to connect an external monitor.
    Try installing DirectX 9.
    Try to enter C: \ Users \ [YourUserName] \ AppData \ Local Low \ Robot Gentleman Studios \ 60 Seconds \ Settings.dat and delete this file, then restart the game.
  • #8 16910016
    dus1eek
    I have DirectX 9 installed, but as for the file I have to delete, it might be a bit bigger problem. This game "60 seconds" is purchased on the steam platform and I installed this game on the D drive so as not to clutter the C drive.
  • #9 16910052
    daminek1234
    Help: 61
    Rate: 88
    Settings and configi are either where the friend gave it (regardless of the installation location) or in the game folder.
  • #10 16910208
    silentyt
    Rate: 42
    Exactly, in most games the configuration files are placed in the AppData folder, no matter if you install on a partition other than, for example, System C
  • #11 16910328
    dus1eek
    Problem solved! After installing DirectX 9 and removing the settings.dat file, the game works as it should :) Thank you to everyone for your time :)
The user experienced a black screen issue with the game "60 Seconds" on a Windows 7 laptop equipped with an Nvidia GeForce G102M graphics card. The game starts normally, but the menu disappears after a few seconds, leaving only sound. After confirming that other games function correctly, suggestions included checking for an external monitor connection and installing DirectX 9. The user was advised to delete the settings.dat file located in the AppData folder. Following these steps resolved the issue, allowing the game to function properly.
