Nokia 3 - Slow Charging Issue: 5-6 Hours, Post CTDI Repair & Tested, Apps Not Affecting Charge Time
karol2013 5712 10
Why does a Nokia 3 take 5-6 hours to fully charge, and how can I check whether an app or the phone itself is causing it?
A Nokia 3 should usually charge in about 3 hours on the original charger, so 5-6 hours is too long unless the charger is weak or some app/settings are keeping the phone busy [#16909467][#16909393][#16909549] The phone does not support fast charging and has a 2650 mAh battery, so a more powerful charger may reduce the time a little [#16909393] A good test is to fully discharge the phone, switch it off, and charge it while powered off; if the charging time is still similar, the problem is not caused by apps [#16909431] If charging becomes much faster after a reset, then an installed app or setting was likely draining the battery or slowing charging [#16913181] If it still takes around 5 hours or more when powered off, the forum advice was to treat it as a defect and send it back again with the measured charging time [#16909549][#16909431]
  • #1 16909293
    karol2013
    I have a problem charging this phone right up to the very beginning. The time it takes to fully charge the battery is about 5-6 hours.
    The phone recently returned from the CTDI website. In the analysis they wrote and the device has been repaired in the device, the system has been prevented. After repair, the device has been tested according to the manufacturer's specifications. The device is working.
    I don't think that any applications that I have installed have the phone taking longer to charge.
  • #2 16909393
    E8600
    Help: 529
    Rate: 2521
    This phone doesn't support fast charging and the battery has 2650 mAh so it's possible it's normal behavior. You can try to give a more powerful charger it can reduce the charging time a little. The Blackberry Z30, which I have also does not have a quick charge with the original charger charging almost 4 hours while on the Samsung 2 A charger the charging time is reduced to 2.5 hours (checked on the charger from Samsung S5 neo).
  • #3 16909431
    michalek1988
    Help: 68
    Rate: 181
    Try to unload it, turn it off and charge it completely. If this time is significantly shorter, then there will be a problem with some application or settings, maybe while using it you can use it, which drains the battery. If, despite its physical shutdown, this time will be similar, return it to the complaint again, including the information about the measured charging time when it was turned off.
  • #4 16909467
    E8600
    Help: 529
    Rate: 2521
    In tests it turned out that this Nokia charges 3 hours on the original charger.
  • #5 16909549
    michalek1988
    Help: 68
    Rate: 181
    I also came to this data, the result below 4h will be acceptable. The time of 3h may be a bit too optimistic, you also have to take into account the wear of the equipment. However, around 5 can be safely interpreted as a continuous disadvantage. Can post service requests here, without contact details.
  • #6 16909564
    karol2013
    I posted my conclusions in the first post.
  • #7 16909577
    michalek1988
    Help: 68
    Rate: 181
    I thought it was an abbreviation, i.e. probably the charger socket was damaged and the battery could be damaged if the service does not mention anything about it.
  • #8 16913181
    karol2013
    Fuck in .... I restored to factory settings (reset) I only updated important applications and started loading. I immediately noticed that the percentages of battery condition began to rise much faster. It followed that some application had a fault, I will observe it a bit and I will install more applications with more consideration.
    EDIT: What antivirus do you propose?
  • #9 17130464
    stworek79
    My girlfriend bought this phone and only turned off 53 percent off for 5 hours, it can be concluded that it takes about 10 hours to fully charge. This is too much.
  • #10 17130593
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    No, often they are responsible for various strange phone anomalies and battery operation.
  • #11 17130600
    karol2013
    The fact sometimes some application silences this phone and the games in general. Read here everything is described: https://pl-pl.facebook.com/CTDI.Polska/
The Nokia 3 is experiencing a slow charging issue, taking approximately 5-6 hours to fully charge after a repair from CTDI. Users suggest that this charging time may be normal due to the phone's lack of fast charging support and its 2650 mAh battery capacity. Recommendations include using a more powerful charger to potentially reduce charging time and performing a factory reset to identify if any applications are causing the slow charging. Some users report that their devices charge significantly faster when turned off, indicating possible software-related issues. Overall, a charging time of around 3-4 hours is considered acceptable for this model.
