[Solved] LG K8 LTE Slow Charging Issue: Takes 5 Hours for 30% - Battery or Socket Problem?
michal652 4104 3
  • #1 17124875
    michal652
    Hello, I have an LG k8 Lte phone and I have had a problem with it for some time because it takes a long time to charge. After 5 hours, it was 30% charged. I have tested it on various chargers, but the same is true for all of them. I wanted to ask what could be the reason for this? Is it the fault of the battery or the socket on the phone?
  • #2 17124901
    nutergsm
    Help: 1034
    Rate: 1665
    If the phone socket is not loose and you do not need to press the charger cable, it is rather the battery fault.
  • #3 17134507
    FSOdzik
    May not be touching on the socket. It also happened with me and it turned out that the cable was to blame. after replacing it with a new one with the same charger, everything returned to normal.
  • #4 17144224
    michal652
    It turned out that the reason for this was a damaged socket, after replacing everything returned to normal.
    I have replaced the socket under warranty.
