Samsung Galaxy J5: Slow Charging Issue - Solutions, Charger Replacement, 5 Month Usage
Zyguli121 4575 3
  • #1 16312335
    Zyguli121
    Hello, I already have 5 months of this Samsung Galaxy j5 and I have had a problem with it for about 2 days charging with slow charging I tried to unload it to zero and charge but it was still the same and I changed the charger and unloaded it again and it was written that slow charging .
    beo
    Level 37  
    Help: 298
    Rate: 238
    Pay attention to the cable. I do not know if the J5 has a quick charge function, but you can install eg AccuBattery and check the state of mA going from the charger. Sometimes a slightly damaged wire reduces the mA. With a completely almost discharged tel, the current should be at least 900mA.
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    White moisture markers? I had so much in the art that after flooding and cleaning it took a long time to load
  • #4 16314780
    barktosek
    Rate: 8
    What are your charger parameters?
