WV Caddy ABS Pump Test Error P01486: Road Test Procedure & Solutions to Extinguish ABS Lamp
citromaniak 21195 11
How can I clear the ABS lamp or complete the road test after interrupting the ABS pump test in VCDS?
You can disable the road test in VCDS by entering login 40168, then going to Basic Settings, selecting channel 103, and pressing Do [#16436903] That option reportedly clears the problem immediately [#16437418] If you want to perform the road test instead, press the brake until the ABS indicator starts flashing, drive straight at about 30 km/h, then make a roughly 90-degree turn and brake again [#16427480]
  • #1 16427179
    citromaniak
    Help: 53
    Rate: 394
    Hello, accidentally, in vcds, I pressed the abs pump test and it was not finished. Then the p 01486 error popped up, i.e. to make a road test on the road. Unfortunately, the car does not want to go through it. I tried various methods given on the forums, but the abs lamp still does not go out. have any idea for this procedure?
  • #2 16427198
    decybel91
    Help: 1024
    Rate: 4231
    unfasten the clamp, try again.
  • #3 16427205
    citromaniak
    Help: 53
    Rate: 394
    and any more tips? because tomorrow there will be a fight all day at the workshop
  • #4 16427480
    bula17
    Help: 52
    Rate: 295
    The option is, press the brake, the Abs indicator light starts flashing, go straight about 30 km / h, turn about 90 degrees and press the brake. Alternatively, vas has an option to disable the road test.
  • #5 16436734
    citromaniak
    Help: 53
    Rate: 394
    And does vcds itself have an option to disable the road test?
  • #6 16436815
    adam7009
    Help: 656
    Rate: 1635
    has such an opportunity
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #7 16436864
    citromaniak
    Help: 53
    Rate: 394
    Can you buddy tell me how this can be done on vcds? I will be very thankful
    raf3000
    Help: 7
    Rate: 28
    try like this:
    login 40168
    basic settings
    channel 103
    do
  • #9 16437418
    citromaniak
    Help: 53
    Rate: 394
    Thank you, it helped immediately. I still have a problem with the calibration of the g85 sensor, after encoding it, it does not see the steering angle, it always sees the steering angle before encoding. and this is how it fits with the ankles. Maybe you need to change the steering angle of the steering wheel to a newer one?
  • #10 16437431
    adam7009
    Help: 656
    Rate: 1635
    It didn't pass the road test, your car is out of order, you won't be able to calibrate the g85, I think you know why.
  • #11 16438393
    citromaniak
    Help: 53
    Rate: 394
    I suspect that the test does not want to pass because g85 is not calibrated
  • #12 16438700
    adam7009
    Help: 656
    Rate: 1635
    something there is wrong to see, speed, steering wheel angle etc ...., it's doing calibrations when stationary.
The discussion revolves around a user encountering a P01486 error after an incomplete ABS pump test using VCDS on a WV Caddy. The user is unable to complete the required road test to extinguish the ABS lamp. Various suggestions are provided, including unfastening the clamp, pressing the brake to trigger the ABS indicator, and driving at a specific speed while turning. It is noted that VCDS has an option to disable the road test, with a specific login and channel settings provided for this purpose. The user later mentions issues with calibrating the G85 sensor, suspecting that the calibration failure is preventing the road test from passing. Responses indicate that the car's malfunction may be linked to the G85 sensor calibration and other related parameters.
