Astra H Ignition Key Issue: ABS/Traction Light On, U2105-00 & B3649-08 Errors Detected
37812 8
  • #1 17306007
  • #2 17306089
    jacek0503
    Help: 28
    Rate: 175
    Buddy- suggests the simplest thing under the sun - disconnect the battery for a few minutes. This is CAN - drama. Maybe it will give something or maybe not but it's worth a try.
  • #3 17306124
    piotrekwoj1
    Help: 939
    Rate: 3401
    Probably incident CIM. After deleting, read again, check the real thing there.
  • #4 17306183
    zybex
    Helpful for users
    Help: 2094
    Rate: 2933
    Maybe it is something completely different, but in the Corsa I could not fire it, I started the starter and nothing else. Some errors were supposedly detected but nothing specific. It happened suddenly after reaching the destination (literally 0.5 km) and turning off the engine. Finally I gave the car to the workshop. It turned out that the timing chain fell.
  • #5 17306226
    kortyleski
    Help: 957
    Rate: 3847
    You must first restore communication with the ECM. The rest will probably solve itself.
  • #6 17306227
    piotrekwoj1
    Help: 939
    Rate: 3401
    And also say that it did not block the engine when you turned the starter.
  • #7 17306299
    zybex
    Helpful for users
    Help: 2094
    Rate: 2933
    I don't know that, but eventually the car on the tow truck left for the workshop. He was towed to me normally before. From what later turned out quite a few things were exchanged, because in addition to the pulled out chain also a set of tensioners and some accessories for that.
  • #8 17306743
  • #9 17375745
✨ The discussion revolves around an issue with an Astra H vehicle where the ABS and traction control lights are illuminated, accompanied by error codes U2105-00 (no communication with ECM) and B3649-08 (left wheel resistance problem). The user reports that the car suddenly failed to start, despite the starter functioning when connected directly. Various troubleshooting steps were suggested, including disconnecting the battery and checking the communication with the ECM. Ultimately, the user discovered a damaged wire in the harness between the battery and the ECU, which was causing the communication failure. After repairing the wire, the vehicle was restored to operational status.
