Oven SAMSUNG BF1C6G080: Touch Buttons Self-Activate, -SE- Error, Display Issues, Repair Options
Piotrhb 12363 2
  • #1 16916144
    Piotrhb
    Dear colleagues, I have the following problem: My wife wiped the oven with a cloth and it beeped several times because the touch buttons were activated. Two days later it started to "pop" on its own and the touch buttons pressed themselves. First less often, a day later more often, and two days later non-stop. I unplugged it. A day later I plugged it in and the same thing - "beeping" non-stop. I unplugged and reconnected it two days later. There is no beeping, but suddenly, after about 30-60 seconds, the error "-SE-" appeared on the display and cyclic beeping - probably every 10 seconds. Now every time I plug it in, after about 30-60 seconds it starts beeping and -SE- appears. I will add that before -SE- turns on, I can turn on the oven - the light works, the convection function works, everything is fine. However, when these half a minute passes, everything stops, starts beeping and -SE- appears.
    My question is: my warranty has expired, is it worth repairing something like this? I don't know if it would be better if I bought a new one because the repair cost would be relatively high. Or maybe it's just a minor thing that I could even fix myself?
    Please help.
    Greetings Piotr.
    MARCIN.SLASK
    Home appliances specialist
    Help: 1038
    Rate: 2663
    An error indicates that some microswitch has been pressed for more than 10s. It is possible that moisture has got on the display module and this is how it behaves now. It remains to repair the module / buy another same oven with another damage or a completely new one. The new module alone is not available, and the purchase of all glass with the module is pointless, because the price is about 900 PLN.
  • #3 16916333
    Piotrhb
    Thank you for the quick reply. Moisture certainly didn't get there. All I can do is sell this oven for a few pennies and buy a new one ... Well. Thank you for the advice
