Samsung Dual Cook BQ1S4T133 - Oven overheating and misting up
ber 7416 8
  • Possible insulation or door seal failure causing overheating
    #1 16737520
    ber
    Help: 8
    Rate: 40
    Some time ago, after a few minutes of operation of the Samsung Dual Cook BQ1S4T133 oven (it was only heating up), the fuses blown, I have the impression that it also smelled a little burnt and a light smoke came out of it. Later, I checked the oven and it worked strangely (e.g. when hot air was on, first one and then the other fan turned off). I left the equipment alone until ... about a month later my wife forgot it was damaged and she just baked something good in it :)
    To my surprise, everything seemed to work properly. Unfortunately, I recently took a closer look at how the oven works and bakes ok, but it heats up everything around (front door, display with knobs, induction hob, cabinets next to it). In addition, the inside of the digital display is steamed up and after opening the oven, large amounts of steam are released (previously it was much less).
    As I have absolutely no experience with ovens, I have no idea how to go about it, if it's worth it and what's inside the oven. Has anyone encountered a similar problem and maybe knows what it may be the fault, what to look for after dismantling the oven?
    Just before a service technician is called, I would like to know if it can not be repaired by myself and what costs can be expected for the repair.
    best regards and thanks for any suggestions.
  • Cooling fan failure suspected as smoke source
    #2 16737570
    tadeq
    Rate: 12
    I have never repaired the oven and please forgive me if I write something wrong. I believe there are 2 fans in the oven. 1 for hot air and 2 for cooling the oven housing. That is, the latter blows the oven from the outside and prevents other elements of the kitchen from heating up.
    My suggestion is that you find this 2 fan and check it. I suspect it is burnt and hence the smoke.
    Regards, Tadek
  • Condensation in EMI filters caused fuse blowing
    #3 16743543
    adat2
    Rate: 17
    Hello, I had the same problem. After a few minutes depending on the moisture in the food, the fuses blown. The problem is simple, i.e. the vapor condenses in the anti-interference filters. The reason for the bad location of the tin can. The problem is removed, I covered the shallow hole and moved the filters to another place (you need to clean the plate underneath it can be soothed, and the water vapor can also be in the lower fan, you also need to wash the fan axis and sleeves.
  • Bottom fan failure suspected in hot-air mode
    #4 17072172
    GabiPas
    a few days ago I had a similar situation. While the oven was heating up, something smelled suddenly and the plugs blown out. Now, when I turn on hot air, the bottom fan does not turn, only the top one and the back heats up to red. The top-down baking function works normally, although I have an impression that it is less. I wonder if the upper fan is for baking or cooling and the bottom one. Has anyone had a similar situation? What could have happened and can you fix it yourself?
  • #5 17074906
    adat2
    Rate: 17
    The thermal fuse will fall soon because there is no circulation, the shaft in the lower fan is seized.
  • #6 17077597
    GabiPas
    Even if he only uses the top-down option?
  • #7 18341900
    pyrokar01
    Rate: 40
    How do I remove the top fan? Because I have a seized axle, probably, and the thermostat hit me
  • #8 18343997
    ber
    Help: 8
    Rate: 40
    It is very simple, after removing the casing, just unscrew / loosen a few screws to slide the fan out of the holders. This is what the removed fan looks like next to the mounting point :)
  • #9 18346261
    pyrokar01
    Rate: 40
    Ok, that is, it is pulled from the inside, not from the back, then how to remove the cover, because so far I have only torn off the back and top?
The discussion revolves around issues with the Samsung Dual Cook BQ1S4T133 oven, specifically overheating, blown fuses, and excessive steam release. Users report that the oven's fans may not be functioning correctly, leading to overheating of surrounding components and condensation inside the digital display. Suggestions include checking the two fans—one for hot air circulation and another for cooling the oven housing—as a potential cause of the problems. Users also mention the possibility of a seized fan axle and the need for proper fan maintenance to prevent thermal fuse failure. Some users share experiences of similar issues and offer advice on fan removal and troubleshooting.
