Opel Astra G: Tachometer, Fuel Temp & Level Issues After Clocks Removal - Seeking Help
Piter1530 8247 5
  • #1 16924756
    Piter1530
    After removing the clocks in my astra g, the tachometer does not work. Fuel temperature and fuel level jam. I have to tap then it picks up. Where is the problem. Will you help?
  • #2 16924776
    headshot
    Help: 32
    Rate: 128
    check the socket and the harness at the meter.
  • #3 16924826
    Piter1530
    This is the problem with the checked and it was covered with a special spray for connector corrosion and it did not help.
  • #4 16924893
    headshot
    Help: 32
    Rate: 128
    I heard about tarnished contacts, which is rare in meters, maybe you sprayed too much and it short-circuits? Why did you splash anyway? And then spray it with a contact for electrical contacts.
    You can also have a well-formed socket or cold February in the meter.
  • #5 16924973
    Piter1530
    They were slightly asleep. This is what I mean with this spray. I'll check the cube to see if it's already over and I'll call you back. I'm only worried about the cold February ?
  • #6 16924984
    headshot
    Help: 32
    Rate: 128
    I rather bet on the ankle and pins in the plug.
