astra g - speedometer tachometer and temperature and fuel indicators do not work
zawiej1 16461 6
  • #1 16627894
    zawiej1
    Rate: 9
    Hello, I bought Astre g 1.8 98 years.
    The speedometer, tachometer and fuel and temperature indicators do not work. After starting the meter backlight turns on. The diode from the lights and the direction works. The radio does not work either. The backlight turns on only until the speakers are silent.
    I will add that after holding the buttons next to the date and time display it shows the speed of the vehicle. Please help. The seller suggested that the fuses are OK. are there any other fuses hidden under the board that I can check ??? Regards
  • #2 16628429
    inot
    Help: 450
    Rate: 819
    Probably damaged array. You did not write whether the other indicators (oil pressure, handbrake, diagnosis) are on.
  • #3 16628829
    zawiej1
    Rate: 9
    Hey, no lights are working. After turning the key nothing lights up. Only when the light turns on the backlight works the meter. What is the board ??
  • #5 16629565
    zawiej1
    Rate: 9
    today I will check these fuses and let me know. The seller said that the fuses ok but I will check. Good
  • #6 16629732
    inot
    Help: 450
    Rate: 819
    Dashboard (instrument panel).
  • #7 16630298
    zawiej1
    Rate: 9
    fault removed Fuse f13 missing.
    Now you can see that the check is burning and the cushion is non-stop but for another story. Thank you for your help
The discussion revolves around a 1998 Astra G 1.8 where the speedometer, tachometer, and fuel and temperature indicators are non-functional. The user reports that the dashboard lights activate only when the backlight is on, and the radio is also inoperative. Initial suggestions include checking specific fuses (F13, F19, F21, F22, F34) related to the display and radio. The user later confirms that a missing Fuse F13 was the issue, restoring functionality to the dashboard indicators, although other warning lights remain active.
