Audi A6 C6: LED Installation in Lamps - Fixing Direction Flow & Blinking Issues, Do Resistors Help?
king395 10929 9
Why do my LED daytime running lights and turn signals on an Audi A6 C6 turn off after a few seconds or stop blinking, and do I need load resistors?
The body module is likely cutting the LEDs off because it does not see the proper bulb load, so yes: use parallel load resistors to simulate the original lamps [#16931625] One reply specifically suggested a 50W/6Ω resistor in parallel, and noted that the module must still “see” bulbs for each LED position, including both turn signals and both DRLs [#16931625] [#16932898] The turn-signal issue was also explained as the module stopping after a couple of pulses when it does not detect the expected load [#16931625] A 25Ω resistor was tried, but a later suggestion was to go smaller, up to 10Ω, for the indicator circuit [#16934254] [#16951067]
  • #1 16930503
    king395
    Rate: 22
    Hello. I have this puzzle.
    I wanted to mount the LEDs to Audi to have nice lights like the polift version, but they were modular LEDs with a floating direction.
    For now, I have not connected the directions because the problem is that the inclusion of the direction this direction flows twice and stops even though the direction indicator is still on. As I want it to flow again 2 times I have to turn the direction on and off.
    How do you make it work as long as the direction indicator works?
    And the second thing:
    On the first day the LEDs walked well as daytime. On the second day both sides work when turned on, after which the left went out after 5 s and a few hours later the left and right behaved so that I turn them on and go out after 5 seconds.
    I will only add that they blinked every 2 seconds as they went.
    My question is whether you need to mount a resistor to them or is it another problem?
    Modular belt:
    Moderated By CameR:
    Online auction link removed
    Reg. 3.1.18. Do not send links that will become inactive after some time. This will cause the discussion to lose any meaning.
    carrier
    Car alarms specialist
    Help: 511
    Rate: 1054
    how do you power up for a short time from aku it also go out? maybe the body module is extinguishing the voltage because the resistance is not correct
    the direction indicator probably similarly after 2 impulses the body module does not "see" the bulb and disconnects
    connect a 50W 6? resistor in parallel, maybe it will improve something
  • #3 16932837
    king395
    Rate: 22
    from the battery I have not tried only I have connected to the plug from the daytime running lights
    how to connect it in parallel? and I need to connect the resistor to one-way directions and to daytime running lights? Is it enough for daytime running lights?
    carrier
    Help: 511
    Rate: 1054
    king395 wrote:
    I have to connect the resistor to one way directions and to the daytime running lights
    for each led, 2 x directions and 2x drl, you need to simulate for the body module that it still has bulbs
  • #5 16932948
    king395
    Rate: 22
    I connected the led to the battery (second car because I have it in the back and it would be hard)
    LEDs are normally lit without interruption, they do not even flash. I joined the directions and they light up as long as they are connected to the plus
    Added after 7 [minutes]:
    I ordered 25 in 25 Om because that's how I found Da advice?
    carrier
    Help: 511
    Rate: 1054
    25? is not 6? but you can try
  • #7 16938542
    king395
    Rate: 22
    I installed 25w and 25?
    LEDs work. I do not know how to directions because I did not mount
    I'll let you know how to mount it on directions
  • #8 16947556
    king395
    Rate: 22
    Hi. Further part ...
    I have this problem now after installing the 50W and 50 ohms resistor
    that the direction goes when he wants to turn it on and off, but every 40 seconds he turns on alone and flies twice
    adds a video (direction indicators are off)
    https://youtu.be/r_y6WjElh6o
  • #9 16951067
    carrier
    Help: 511
    Rate: 1054
    give smaller resistor max 10?
  • #10 16953147
    king395
    Rate: 22
    then you can literally buy the ones you recommended
The discussion revolves around the installation of modular LEDs in an Audi A6 C6, focusing on issues with direction flow and blinking. The user experiences problems with the direction indicators, which blink twice and then stop, requiring manual toggling to reset. Suggestions include connecting a resistor in parallel to simulate the presence of bulbs for the body module, with recommendations for using a 50W 6Ω resistor. The user tests the LEDs directly from the battery, confirming they light up continuously without flashing. After trying different resistors, including 25Ω and 50Ω, the user reports intermittent functionality of the direction indicators. Further advice suggests using a smaller resistor, around 10Ω, to stabilize the system.
