Audi A6 C6 (2006) - Dipped Headlights Not Working, Error Codes 00978 & 00979, Seeking Diagram
sadek1979 18642 2
  • #1 16694364
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    As in the subject of audi A6 C6 2006 no dipped beam front. The position lights are on, the road also only no passing (rear is everything). Light bulbs in working order, fuses also ok. After connecting the computer, errors 00978 and 00979 lamps for low beam left (right) open or short to plus. After deleting, of course, the error returns. The measuring blocks see the position of the switch, i.e. 0,1,2,3. You can also see the lights on and the lamps dark. I am asking for a diagram of lights in this model. It is strange that the right light came first and left after two days. I am asking for your hints. best regards
  • #2 16694557
    kozik20l
    Help: 9
    Rate: 16
    In the bornetz module in a black 10 pin cube, pin 10 is the left passing light, see if the signal comes out. It goes through the 17-pin cube in the pit, if I'm not mistaken pin 17, water could get in there.
  • #3 16900654
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Disconnecting the battery for more than half an hour, cleaning the module in the trunk did the trick. Thank you for your help .
