A6 C5 Avant: Automatic Low Beam Issues, Light Automation, Burnt Filaments & Wiring Concerns
mafialosoo 9078 3
  • #1 16374770
    mafialosoo
    Rate: 19
    Hello all! I have a problem with the lights, namely with their automation that someone did, the car comes from Denmark. Lights turn on automatically when the key is turned off, and when I want to start the engine they go out and light up again. That is why filaments often burn. When the light switch is turned to 0 everything shines ok, after turning to the position of the traffic lights the lights are on but the clocks go out. When the rear or front fog lamps are switched on, the entire rear cut-off lights neither the fog lamp nor any of the rear lamps. I undressed the switch and saw that someone was up to something. A 6A resistor is inserted there and as you can see in the picture, the blue resistor from the bottom the rest from the top all together. I thought to solder all 1: 1 wires but I don't see blue anywhere and I don't know where and what I should connect it with, it could be added extra.
    Maybe someone would have a plug-in scheme which color is responsible for? I am asking for help if anyone knows anything in this topic.
    A6 C5 Avant: Automatic Low Beam Issues, Light Automation, Burnt Filaments & Wiring Concerns A6 C5 Avant: Automatic Low Beam Issues, Light Automation, Burnt Filaments & Wiring Concerns A6 C5 Avant: Automatic Low Beam Issues, Light Automation, Burnt Filaments & Wiring Concerns A6 C5 Avant: Automatic Low Beam Issues, Light Automation, Burnt Filaments & Wiring Concerns
    Regards Michał.
  • #2 16374777
    andrzej20001
    Help: 1578
    Rate: 6669
    Return the beam to the original. And put on a good daytime running led. Or a drl module for high beam.
  • #3 16374784
    mafialosoo
    Rate: 19
    I tried to do it but the blue color remains for me. I don't have a second blue to connect
  • #4 16391869
    mafialosoo
    Rate: 19
    Would any of you have a diagram of the light switch cube? Which pin is the color of the wire ?? Audi a6 c5 2002 2.4b
