Win XP Installation on 850 Pro SSD (256GB): Optimal NTFS Cluster Size (4KB or Any)
stefan9999 5427 7
  • #1 16936794
    stefan9999
    I plan to install win xp on a new 850 pro ssd (256GB).
    What cluster size should be set after creating the partition before formatting in NTFS - must it be 4KB or can it be any?
    Thanks in advance for any help.
  • #2 16936857
    DriverMSG
    Help: 3984
    Rate: 4883
    Read about TRIM, XP and SSD is a very bad idea, and the victim will be the disk itself.
    Create partitions from a newer operating system (7,8,10) and if you have the option to switch SATA mode in AHCI - you may need to integrate the drivers with the XP installation disc.
  • #3 16936859
    gumisie
    Help: 1667
    Rate: 2483
    I'd rather use google and check if win xp supports this type of disk (SSD). :D
    best regards
  • #5 16937685
    stefan9999
    I read a lot of articles and topics on the forums regarding xp on ssd and I know that this system is not optimized for ssd drives (despite this, a lot of people use or use it on such a disk with positive results).
    The only thing that I still do not know completely is the cluster size I mentioned at the beginning which should be set when formatting the partition, I came across conflicting information: some say that it is necessary to set 4KB, others that it is best to set the default.
    Can anyone tell me what cluster to set up?
    ps. Partition planning and alignment plans to do with the gparted program, regarding ahci - I'm currently using this mode, integrated drivers
  • #6 16937728
    Dra98
    Help: 1321
    Rate: 1076
    To prepare the disk / partition just use Vista / Windows7. Under XP this is also possible only requires a little bit of effort.
    I have Windows Vista Ult.
    Regarding TRIM, you can use the # 9 method on old systems -
    https://www.elektroda.pl/rtvforum/topic3367576.html#16640396
  • #7 16937830
    stefan9999
    ok ... but I still don't know what cluster size to set by formatting the partition - 4KB or default ..
  • #8 16937848
    Kasek21
    Help: 4981
    Rate: 3547
    Leave Default.
The discussion revolves around the installation of Windows XP on a Samsung 850 Pro SSD (256GB) and the optimal NTFS cluster size for formatting the partition. Users express concerns about the compatibility of Windows XP with SSDs, noting that the operating system is not optimized for such drives, which may lead to performance issues. There is conflicting advice regarding the cluster size, with some suggesting a 4KB size while others recommend leaving it at the default setting. The importance of using a newer operating system for partitioning and the necessity of enabling AHCI mode for better SSD performance are also highlighted.
