Partitions for HDD & SSD - Optimal Setup with System Installed on SSD
GKarol99 10533 16
Should I partition the HDD if the operating system will be installed on the SSD?
You can partition the HDD, but it is not necessary; many recommend leaving it as one large partition and organizing files with folders instead. Changing partition sizes later can be difficult, and one partition may fill up while another stays underused, so a single large volume is often simpler [#16556093] Partitions do make sense if you want to separate data for order, format only part of the disk without affecting everything, or use one part for another OS or backups [#16560083] Several replies also note that on a 1 TB HDD there is no need to split it unless you personally prefer that layout [#16558174][#16554664]
  • #1 16554359
    GKarol99
    If I have HDD and SSD, is it good to do partitions on HDD? The system will be installed on the SSD.
    Thanks in advance
  • #2 16554664
    sosarek
    Help: 9320
    Rate: 15532
    Personally, I create partitions on a disk, even to have a relative order, except if it is necessary to format one of them, I do not lose data from the whole disk.
    Z
    Pka, Poznań, 60-850
  • #3 16554769
    Piotr160292
    Help: 374
    Rate: 282
    In my opinion, no sense as SSD is to be only on the system.
  • #4 16555191
    Robert B
    Help: 2027
    Rate: 1412
    GKarol99 wrote:
    HDD drive
    And the disk capacity is a state secret?
    SSD does not share, because it does not make sense.
  • #5 16555477
    GKarol99
    HDD 1TB
    SSD 120GB for starters
    I do not intend to share the SSD, I mean HDD
  • #6 16555490
    Piotr160292
    Help: 374
    Rate: 282
    You can divide 1 TB into even programs and data ...
  • Prefer one large partition over fixed splits
    #7 16556093
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Dividing a disk into a partition for "something" and a partition for "something else" has one major disadvantage. Changing the proportion of this division after it is made is very difficult. One partition will usually fill up sooner, and the other will be replaced. In connection with this then the next logical step is to match the partition, on which everything is left as it flies.
    The assumption that the division is made to keep order in this case falls.
    Instead of dividing the disk into partitions, it is better to leave one large and create folders in the main directory for anything and in this way to make a division. The whole place is available for everything. However, being able to do any number of folders and not having to guess how much they will occupy in a while, it's probably easier to organize.
    But what does he like. Having SSD and HDD on both I would set up one partition of the maximum size - which does not mean that cutting any disk on the part is an incorrect approach.
  • #8 16556098
    Robert B
    Help: 2027
    Rate: 1412
    Well, that's it. I also have 2TB discs in one piece.
    dt1 wrote:
    create folders in the main directory for anything and in this way make a division.
    exactly :)
  • #9 16557300
    Piotr160292
    Help: 374
    Rate: 282
    I'm being stupid ... For just because MFT will tell you papa and you have all the data, and you lose some of it ...
  • #10 16557327
    Robert B
    Help: 2027
    Rate: 1412
    If you can not recover after such a small damage, it's your business and you can even divide yourself into one hundred parts :D
  • #11 16558132
    Piotr160292
    Help: 374
    Rate: 282
    I can - DMDE or testdisk and driving, but not everyone is experienced enough, and not everyone can afford to recover on the site. I have had a problem that the partition was not seen as RAW, but it disappeared completely and I had no problem with entering it back into the MFT and reconstructing the file system ...
  • #12 16558174
    sylweksylwina
    Help: 1882
    Rate: 2355
    I think it's a personal matter, who likes it. Personally, I have divided SSD (250GB) into a system + programs / games, and I have only one partition on HDD 1TB and 500GB.
    In your case, there is no need to share HDD. All you have to do is defragment the HDD from time to time, in any case it should be done ...
  • #13 16560083
    DriverMSG
    Help: 3984
    Rate: 4883
    Two issues should be considered here.
    1 - Partitioning a disk increases data security.
    As mentioned above, it is always possible to format one of the partitions or use it for other purposes, e.g. a different operating system, SSD backup, etc.
    2 - Copying data between partitions is very slow, so you do not have to waste a lot of time in sorting and moving files.
    And in so doing, the author's question:
    GKarol99 wrote:
    is the point to make partitions on HDD?
    You have to make partitions to use the disk, and if it's one, two or more, it's your will.
  • #14 16560263
    Piotr160292
    Help: 374
    Rate: 282
    I forgot to refer to this:
    This is very interesting, because I personally often narrowed and expanded both the partitions with data and programs, and the system, and practically never had any problems with it. I wrote practically because one time I had an action from my father with a laptop, that after MFT's interference with the partition system, one partition disappeared, but after rebuilding the MFT everything was ok. Personally, I carry out such operations using Easus partition master ... There is one principle . If there is an interference with the size of the partition, this partition should be defragmented and practically the chances of being released are zero at this point ... Of course, we are talking about magnetic disks, because in the case of SSD it is a bad idea to defragment partitions. Even defragmentation programs do not allow such an operation if they determine that the partition belongs to the SSD.
  • #15 16560540
    dt1
    Help: 7315
    Rate: 8292
    There is nothing interesting in this statement. Changing the division is not impossible, it is difficult and it is not the safest operation. A colleague within the framework of security prefers to make several partitions, because he may some time damage, I prefer not to change the partition divisions when they are given - because the chance of their damage is even greater. So I do not see any interesting or new insights here.
  • #16 16561140
    Piotr160292
    Help: 374
    Rate: 282
    Whatever, whatever. You can do DFT MFT VIA DMDE and the problem does not have ...
  • #17 16561173
    dt1
    Help: 7315
    Rate: 8292
    The only thing to be happy is that the colleague can copy the MFT (knowing exactly how much it takes) and that in case of a failed file transfer operation, if the size of the partition is reduced, the colleague will be able to do something with his copy of the MFT.
    I still think that this type of surgery is not safe and I avoid it if possible.
The discussion revolves around the optimal setup of partitions on HDDs and SSDs, particularly when the operating system is installed on an SSD. Users express differing opinions on partitioning HDDs. Some advocate for creating partitions for better organization and data security, allowing for easier management and potential recovery options. Others argue against partitioning, citing difficulties in resizing partitions and the inefficiency of data transfer between them. The consensus leans towards keeping the HDD as a single partition for flexibility, while SSDs should remain unpartitioned to maximize performance. Users also mention the importance of defragmentation for HDDs and the risks associated with partition management.
