[Solved] Indesit PBAA 13V fridge - does not cool, characteristically rashes, ticks.
Szechem 7833 4
  • #1 16937792
    Szechem
    I have had a problem with this fridge for two days. It works like on the attached movie, it cools almost at all (in the freezer about 0-2 degrees, in the refrigerator over 10). I asked two service technicians over the phone, they suspect that the installation is unsealed or the compressor has failed.
    I am asking for help. I would add that the fridge worked for a while "normal" when I moved it, after the next move it goes the same again. The day before, you could hear the characteristic ticking, as if the suspension in the car or the old work board creaked.
    Code from the type plate: 34618050300
    [Film: fc18a8a0bf] https://filmy.elektroda.pl/29_1515158738.mp4 [/ film: fc18a8a0bf]
  • #2 16937862
    jack63
    Help: 851
    Rate: 2822
    Cool video. Have you boasted and what's next? What exactly do you expect from the forum?
  • #3 16938019
    Szechem
    Sorry for the error, I didn't know that the forum converter cuts the sound after formatting videos from iphone to mp4. That's why we didn't get along
    I put links to the movie in the original format https://drive.google.com/file/d/1EUdRKuwzLnM1Ofyy42ErGFJ3e4YILffq/view?usp=sharing and MP4 https://drive.google.com/file/d/1rZtHR8zN-vfzZzl2BF01Pt285? usp = sharing
    This is a sound recording made by a fridge during operation. However, this is an effect from yesterday. As I wrote earlier, 2-3 days ago it ticked in a characteristic way, as if the suspension in the car creaked from pressure.
    I suspect a fault somewhere in the refrigeration system. I checked if it was not a small thing in electricity or, for example, some clogging in the evaporator, because I met with something like that, but these systems look fine.
  • Refrigerant leak likely; non-nofrost fridge may be scrap
    #4 16942796
    jack63
    Help: 851
    Rate: 2822
    The subject of the recording is not important. I managed to listen to it after setting all possible reinforcements to full.
    With the rest, as far as the sound was concerned, why the movie?
    However, the recording does not show much. Maybe it is a result of high gain? Or maybe the wrong position of the microphone?
    Does not matter.
    Refrigerant leakage is most likely.
    If the fridge is not nofrost, it's likely scrap metal.
    Turn it off, because it cannot be used anyway, and you will run the compressor to death and if the system could be sealed or the leakage was minimal, fill it to work a little more, the compressor will be useful ...
  • #5 17211266
    Szechem
    Good morning,
    Problem solved. There was no leakage. I took it to Międzylesie. The reason was the pump, which could be heard.
    I close the topic
