[Solved] Refrigerator Beko CN228220X - does not cool properly, red exclamation mark flash
IvanSoft 32805 3
  • #1 17064734
    IvanSoft
    Rate: 13
    I warmly welcome,
    The problem concerns the refrigerator (fridge-freezer) as in the subject: Beko CN228220X, serial number: 1210119803, used for 5.5 years ...
    On the touch control panel, a pulsing red exclamation mark appears from time to time. I put an electronic thermometer in the refrigerator, put in a container with water and it turns out that the temperature of the liquid is too high - at a set temperature of + 6 ° C, the liquid can be 9-11 ° C, that is, food spoils.
    The fridge can cool to the set, set temperature, i.e. the thermometer showed around 6 ° C, but it can not keep this temperature anymore.
    Yesterday at various times of the day, I wrote down the time and temperature of the liquid in the vessel with water, the place of measurement was constant. I also wrote down whether the aggregate was audible, and so:
    9:45 - 6.1 ° C - the unit is working
    10:27 - 6,7 ° C - the unit is working
    11:31 - 8 ° C - the unit is working
    12:18 - 7.8 ° C - silence
    15:03 - 10.4 ° C
    16:45 - 9.3 ° C - a red exclamation mark flashes, the fan in the freezer works, the unit walks.
    21:24 - 8.7 ° C - the unit is working
    today, 10:36 - 9,4 ° C - the red exclamation pulsates, the fridge was silent, after some time the aggregate turned on.
    The fridge was opened for a maximum of two seconds to save the temperature.
    I was already at my service with Beko, he checked, the refrigerator was tight, the refrigerant (gas) is, and the unit worked ...
    In short: the fridge functioned as it should during his visit, the temperature in the freezer within 10 minutes fell to + 5 ° C, did not locate the fault, he said it could be something with electronics.
    I would like to add that the fridge was turned off for a few days before the technician's visit, and I turned off because the refrigerator was already at room temperature, while in the freezer the food started to thaw, and the thermometer pointed to + 1 ° C. - at -18 ° C set
    What could it be? I am able to repay the transfer / PayPal for a properly diagnosed fault.
    Thank you and best regards.
    Update: (26/02/2018 at 10:40)
    Today in the refrigerator the temperature is close to room - over 17 ° C, in the freezer the food is thawed, the temperature (nerves and time) I did not measure, because it looks positive. The red panel has an exclamation mark, you can hear the quiet buzzing of the compressor, the fan is operating in the freezer. I will add that yesterday in the refrigerator the temperature dropped to a set temperature of +6 ° C, the compressor turned off, the fridge was quiet, but today in the morning the room temperature in the refrigerator ...
    miro45
    Rate: 14
    Is the condenser getting warm when the unit is running?
  • #3 17067447
    IvanSoft
    Rate: 13
    Yes, warm, I checked a moment ago - in the middle over 16 degrees Celsius.
  • #4 17074760
    IvanSoft
    Rate: 13
    I solved the problem by buying a new fridge.
    And the brand Beko STANOWCZO I will DISCOVER - if it breaks down, do not count on their service, which you have to wait for over two weeks. Two weeks, by the fridge.
