Seeking Recommendations for Network Load Monitoring Program for Wifi & RJ-45 Connections
lolek2417 4047 4
  • #1 16938201
    lolek2417
    Help: 9
    Rate: 76
    Hello to you
    I have a question: What program do you recommend to monitor the network load?
    I am connected to the router via RJ-45 cable, at home I have a large family (which is connected to the router via wifi network ) and I would like to know who is downloading the most data at the moment?
    For example, I would like to have a preview of when a given family member No. 1 at some point does not start the torrent, which fills the entire transfer - I would recognize it by the mac address.
    Is there such a program at all?
    I will only add that, unfortunately, in many cases, even if I ask directly a given delinquent, whether he or she is downloading something, the answer is always the same - no.
  • #3 16938259
    lolek2417
    Help: 9
    Rate: 76
    Tell me, according to Ciebei, which of the programs on this page will be the best?
  • #4 16938271
    Pedros050
    Help: 2471
    Rate: 3921
    York Network Trace 1.61 is the simplest one and you should do it, and by the way, they're all good. Can you download and test which one suits you best?
  • #5 16938379
    lolek2417
    Help: 9
    Rate: 76
    Thanks for closing
