TP-Link W8910G – how to check which PC downloads the most data?
naimadp 35916 19
How can I check which computer on my network is downloading the most data per device?
You generally cannot get useful per-computer traffic statistics from this setup without changing the router firmware or hardware. The best solution in the thread is to use a router that supports Tomato/OpenWRT/DD-WRT and then add iptables rules or traffic-shaping/accounting to count download and upload per IP, ideally with IP-to-MAC bindings and ARP bindings so devices can be tracked and limited [#9059540][#10066377] The stock TpLink W8910G only shows overall traffic for the link, not separate totals for each client, so it will not tell you which computer is using the most data [#9059585][#10073247] If you cannot change the router, the only workaround mentioned is to disconnect clients one by one or filter wireless MAC addresses to identify the heavy user, but that is an invasive manual method [#10066377]
  • #1 9059515
    naimadp
    Rate: 28
    Hello. Please tell me how I can check who is downloading how much data in the network. I want to know if someone, for example, does not download movies all the time .. There are about 10 computers. All connected under TpLink W8910G. 4 via cable 4 wifi. Only I connect additionally via 2 Nanostation 5ghz antennas and on my side dlink sends the net home. I have access to every device, except for the computers in the network.
  • #2 9059540
    witux
    Help: 390
    Rate: 252
    You need to buy a device that supports Tomato Firmware, additionally load the bulletin board and enter the appropriate iptables rules into the Firewall script for counting Down / UP statistics for specific IPs.
    This will probably be the cheapest solution.
  • #3 9059557
    naimadp
    Rate: 28
    Thanks for the answer. And you can't check with commands somehow. Or some program. When it comes to buying equipment, it is out of the question. It's just not profitable for me. I just wanted to know if anyone is downloading too much.
    And when it comes to IP data, it is out of the question. The IPs in mine turn into because they are assigned automatically. It's going to be too much trouble to get everything sorted out.
    And at a given moment, it is possible to check who is downloading how much? For example, the IP address of the computer.
  • #4 9059567
    stylu
    Level 19  
    Rate: 32
    Don't you see active customers from this link? It should show the amount of Rx and Tx packets sent
  • #5 9059585
    naimadp
    Rate: 28
    stylu wrote:
    Don't you see active customers from this link? It should show the amount of sent Rx and Tx packets
    I have a list of clients, next to it is the MAC address, IP and from which the computer is turned on. Although the latter works differently. So I don't even know how to check how many computers are connected at the moment.
    As for the number of packets, I have a second tab and it writes downloaded sent there, but all together on the cable and on the wifi. It won't do me any good.
  • #6 9059696
    witux
    Help: 390
    Rate: 252
    So if you already have trouble with leeches, switch to a device with advanced QoS. You will assign users IP to MAC, make ARP bindings so that someone outside the DHCP scope will not use the Internet (You will limit unlisted devices). You will allocate a guaranteed and maximum transfer for everyone, leaving a little spare and no one will disturb anyone and clog the links.
    And you will check transfers, e.g.
    And Tp-Link will serve you as an ADSL modem.
  • #7 9060062
    naimadp
    Rate: 28
    But I didn't say that someone was blocking this link for me. I mean the Internet well, sometimes in the evening a little worse and I wanted to know if it was the fault of the internet provider or these people. If I have to change devices, etc., I will let it go. For now it's OK.
    I just thought that it could be checked in a simpler way, but if it is impossible, I close the topic and thanks.
  • #8 9065144
    leszekppp
    Rate: 273
    I had exactly the same, even disconnecting the net, it turned out to be my speedtouch 510 fault, I replaced it and now it's good.
  • #9 9067551
    blues
    naimadp wrote:
    But I didn't say that someone was blocking this link for me. I mean the Internet well, sometimes in the evening a little worse and I wanted to know if it was the fault of the internet provider or these people. If I have to change devices, etc., I will let it go. For now it's ok, I just thought it could be checked in a simpler way, but if it is impossible, I close the topic and thanks.
    Unfortunately, you won't learn anything in this configuration. You need to change the router to something that will be more configurable - there are many possibilities here ...
  • #10 10066287
    simson943
    I have the same problem
    Only a different device
    ADSL2 MODEM LINKSYS WAG120N
    Is it impossible to programmatically without mixing in the device?
  • #11 10066377
    blues
    Other device only LINKSYS WAG120N ADSL2 MODEM
    If you do not have such an option in the standard software, all you have to do is look for an alternative (tomato, openwrt). But it seems to me that there is no such possibility on DSL models (it needs to be checked).
    Of course, it is always possible to disconnect the connected clients one by one and thus find out who is causing the problems. In the case of wired - a very simple matter (cable by cable). For wireless, you filter MAC addresses one by one. But it's an invasive method. How can you change the soft, do it. You will gain a lot more very useful stuff - you might be interested, for example, shapping per-user :)
    :) But it all takes care of programmatically :)
  • #12 10066404
    simson943
    Please brighter,
    I know computers a bit, but GEEK is not me.
    What to check? How to set?
    100% of someone connected to the WIFI sucks.
  • #13 10066491
    blues
    simson943 wrote:
    Please brighter,
    I know a bit about computers but GEEK is not me.
    What to check?
    Is it so hard to type in google, for example "openwrt"? The first link is the home page.
    As much as 2 clicks further there is a list of supported hardware: Link . There is also tomato, dd-wrt, and a few other alternative router firmware.
    Forgive me, but I don't want to browse through the lists to see if your specific router is supported. An exchange would definitely solve your problems.
    simson943 wrote:
    How to set? 100% of someone connected to the WIFI sucks.
    I described what can be done on foot to remedy the situation. But this is only a half-measure and you will have to do all the work again next time. Replacing the firmware with one with shapping, statistics and queuing solves the problems once and for all.
  • #14 10070192
    simson943
    No, it's not that hard to check and of course I did.
    However, both programs interfere with the modem, ie its software.
    I mean a sniffer, something like CommView, but not that exact, why should I know where what packet is going. It's all about simple statistics, which IP or which computer (by name) gets the most and that's it.
  • #15 10070261
    blues
    Of course they interfere, otherwise you can't put anything on the router.
    Well, there's nothing like writing what's going on :P
    Wireshark is available for free.
  • #16 10070377
    piterus99
    Help: 1084
    Rate: 328
    With Wireshark or Commview you will not see what exactly is going to it, the specificity of switches and network cards will not allow it.
  • #17 10070395
    blues
    I wanted to write it too, but here it is about wifi, so it can work (depending on the network card).
  • #18 10071342
    simson943
    Wireshark is the same as CommView
    Do you know how to set it to show network statistics?
    The WIFI card is built into Dell laptop
  • #19 10073247
    blues
    Rather the other way around :P
    But this is a sniffer, not a statistics program. You have to be able to use it and understand a little what you see, otherwise I don't bode well for you.
    You will get the statistics as I wrote at the beginning - the appropriate firmware for the router. So we go back to the beginning.
    PS: moooo, maybe even etherape would work.
  • #20 10209959
    rogerowaty
    ... join the topic because I also have a problem with "leeches"
    By the way, maybe some of you know how to see what is currently being sucked in, using dd-wrt or wireshark.
    It seems to me that the "drunks" somehow outsmart the QoS mechanisms, and I often see that the hosts connected to the lan refer to port 80 of the external addresses.
    p2p probably doesn't work on it or I'm out of date: /
    Do you have any idea how to spot the drunks?
The discussion revolves around methods to monitor data usage on a network with multiple devices connected to a TpLink W8910G router. Users seek solutions to identify which devices are consuming excessive bandwidth without investing in new hardware. Suggestions include using advanced router firmware like Tomato or OpenWRT to enable detailed traffic statistics and QoS (Quality of Service) settings. Some participants mention using network monitoring tools such as Wireshark and CommView, although these may require technical expertise to interpret the data. The conversation highlights the challenges of monitoring traffic on dynamically assigned IP addresses and the limitations of the current router's firmware.
