Measure Data Downloaded on TP-Link TL-WR841N Router: Monitor Internet Usage Across Devices
25071 5
  • #1 16414271
  • Router shows global traffic, not per-device statistics
    #2 16414306
    Epic
    Level 30  
    Help: 147
    Rate: 108
    After all, this information is displayed on the screen. In the "Traffic Statistics" section you have information on how many bytes were sent and downloaded from the external network.
    If you mean specific values for each user / device then this router does not keep such statistics. You can get them only by comparing the values from devices that you already know about using the network, for example the mentioned Windows 10. For example, by subtracting downloaded data from Windows 10 from the global value in the router, you get approximately the total value of downloaded data by other network users
  • #3 16414312
    jimasek
    Help: 3783
    Rate: 2681
    As above, unless you use any alternative software for this TP-link, eg Gargoyle in which these statistics are more extensive.
  • #4 16414418
  • #5 16416294
    gnome3
    Help: 10
    Rate: 10
    In Gargoyle, there is not only counting for each device separately, but you can set the QoS after downloading / sending the amount of data.
    In my opinion, this is the first thing that should be done with TP-Link devices - playing Gargoyle software.
  • #6 16419987
