Audi A3 8L 1.9 TDI 90 km: White Smoke and Unburned Fuel Smell at Cold Start
casaq 18414 9
Why does my Audi A3 8L 1.9 TDI smoke white and choke briefly on cold start, even though the glow plugs seem to work when the coolant temperature sensor is disconnected?
The cold white smoke and brief choking are most likely caused by a fault in the glow plug system/control circuit, and if the injection angle is already set, the next things to check are the injectors, compression, and the air flow meter [#16940093][#16939426][#16939358] One reply says that a glow-plug fault code usually means either the plugs themselves or their circuit is wrong, so the glow plug controller/relay and wiring should be checked [#16940093] Another recommends computer diagnostics and checking the air flow meter [#16939358] If the injection angle and ignition timing are correct, there are not many other reasons left besides injector condition and engine compression [#16939426] The described behavior—smokes white for about 3 minutes, then runs normally after a few throttle blips—fits a cold-start fueling/control problem more than a permanent power loss [#16940343]
  • #1 16939151
    casaq
    Rate: 8
    Hello . I am the owner of the Audi A3 8L 1.9 TDI 90 km.
    The problem is that when starting, on a cold engine, it will kick white. The smell of rather unburned fuel (although I may be wrong). There was a problem with candles before. They are all functional, I checked. Just don't rummage. If the sensor is detached from the water temperature, it will heat normally. If I step on, they don't heat at all. But it's probably the cube's fault, because even on a new sensor (without putting it, drained with cold water from the fridge, they also do not heat). In general, even on a connected sensor, where the candles did not heat, he also kicked, but now despite the fact that he smokes, if I add gas to him for 2 thousand turns, something shakes him, as if he was choking. I went through a lot of topics, some say it is coolant, others say different. I don't know what it can be anymore, because a lot has been done with this car. For example, injection angle and ignition timing (because the timing was changed) before the operation, on a cold engine it was not choked, but there were also exhaust fumes. Even if it was well over +2 degrees. So I doubt it's a couple. The coolant does not decrease, there is less oil, but I have already made over 7,000 km on this oil, so something could have gone.
    I don't know what the reason may be anymore, so advise what it could be, consider and check it out if I can do it.
  • #2 16939358
    DriverMSG
    Help: 3984
    Rate: 4890
    Computer diagnostics done? Are there any mistakes?
    Have you checked the air flow meter?
  • #3 16939368
    piotrekwoj1
    Help: 947
    Rate: 3438
    First make the candles warm.
  • #4 16939426
    Sel
    Help: 7
    Rate: 59
    As far as my memory is not mistaken, the engine only burns candles for -5 and only a few seconds. I suggest checking the injectors and compressions, because if the injection angle is set correctly, there are not too many reasons for digging.
  • #5 16939962
    casaq
    Rate: 8
    Diagnostics done. It showed errors with the injection angle and ignition. And with candles. The injection angle has been set, and the ignition also. Candles are burning, only on the detached sensor from the water temperature.
    I did not check the flow meter.
    I heard that in this engine, candles should heat even from +9 degrees. Be even at 0 degrees. And the candles were checked at 0 or -1 degrees.
    EDIT. I will only add that the engine chokes only when I start it on cold. If he gasps him 2-3 times to 2 thousand turns, then he does not choke. The engine has power, it doesn't cut it off.
  • #6 16940093
    piotrekwoj1
    Help: 947
    Rate: 3438
    Since you have a candle error, something is wrong with them or the circuit.
  • #7 16940133
    casaq
    Rate: 8
    I wrote at the beginning of the topic that it showed errors with candles, because the candles did not heat. When the sensor reaches the water temperature, it heats normally. I bought a new sensor, cooled it with cold water, and connected it dry. and they didn't heat, so I think it's a cube. But the candles heat up with the sensor unfastened. I mean white smoke from the exhaust pipe, and it's strange choking of the engine on a cold engine. If I give him up to 2,000 turns, he behaves as if he was coughing. I don't know how to describe it exactly. White smoke only appears for about 3 minutes. When I leave the piece, it disappears. Same with 'choking'. He only chokes him when he starts firing up to 2,000. As it gasps 2-3 times, it stops.
  • #8 16940321
    piotrekwoj1
    Help: 947
    Rate: 3438
    Ok but did you fire on the detached sensor?
  • #9 16940343
    casaq
    Rate: 8
    Yes, I started it. And the candles heat up, and the car behaves the same. White smoke from the back, and choking up to 2 thousand turns for a few moments. Later everything returns to normal. I will go a bit, and there is no smoke or strange choking of the engine
  • Cold-start white smoke points to injection timing issue
    #10 19029817
    EZBERT
    Hello, I have the same problem when starting the car for a while as if it did not burn on any of the cylinders, after adding gas it calms down immediately and it works normally but it smokes white for a while, it has this problem when it is cold. The candles are working, the wires from the candles, and the temperature sensor is also okay, I don't know what could be the reason. The second thing is that yesterday I installed a resistor on the pump and on a hot engine from 3,000 it starts to mound quite strongly in white and it should mound black. Oil does not burn, coolant also does not take. Since I have the car, I have not noticed that he was kicking black even once, as I can see it, only white color.
    The car is audi a3 8l 1.9 90km agr
The discussion revolves around an Audi A3 8L 1.9 TDI 90 km experiencing white smoke and a smell of unburned fuel during cold starts. The owner has checked the glow plugs, which are functional, and noted that the engine chokes when starting cold but runs normally after a few moments. Diagnostics revealed errors related to the injection angle and ignition timing. The owner suspects issues with the coolant temperature sensor, as the glow plugs heat up when the sensor is disconnected. Other users suggest checking the air flow meter, injectors, and compression, as well as confirming the functionality of the glow plugs and their circuit. The problem seems to resolve after the initial cold start phase, with no further smoke or choking once the engine warms up.
