Samsung Galaxy J3 (SM-J320FN) Android 5.1.1: Auto On/Off, Empty Memory Card Issue & Charging Fix
puchatek1964 12714 6
  • #1 16987545
    puchatek1964
    Nothing happened, did not fall, was not flooded but yesterday there was a problem with my phone: first he stopped seeing the memory card claiming it is but empty and then suddenly started to automatically turn off and on, every few minutes a screen alternates logging in and after logging in turns off and on to the login screen. This phenomenon stops when it is connected to the charging either to the network or to the computer. As long as all functions work, it seems to work. The battery has been charging normally so far, it did not discharge excessively quickly, now the condition is about 90%
    model number SM-J320FN version of Android 5.1.1
    Please help.
  • #2 16987581
    leonov
    Help: 1039
    Rate: 2247
    For starters, restore to factory settings, as it will not help to upload Odin new ROMU.
  • #3 16987608
    puchatek1964
    restoring settings or losing everything that is later like this? Will just copying to a computer drive help in later restoring settings, calendar data or phone book?
    what does it mean to rip new Rom away?
  • #4 16987638
    leonov
    Help: 1039
    Rate: 2247
    Do not have a copy in the google cloud ??
    That's what I wrote, uploading a whole new ROMU (system), to the phone with the Odin program.
  • #5 16987705
    puchatek1964
    [Quote = "Leonov"]
    Well, I do not have copies in the cloud, because generally I do not like to play too much in the ether, it can always dissolve somewhere - I only believe in particulars. If it were not for the technology that makes life easier, I would remain in the analog world. I can create a cloud while the phone is working but it's not something I do every day :P
  • #6 16989042
    el_danone
    Help: 21
    Rate: 25
    Is the phone turned on after inserting the battery? If so, check / clean with brush IPA switch on and USB connection.
    If you do not turn on yourself, you should restore the factory settings / wipe by recovery menu or make a softa.
  • #7 16989345
    puchatek1964
    the matter was solved - the problem was the memory card that apparently had been damaged. After it was removed, everything returned to normal.
The user experienced issues with their Samsung Galaxy J3 (SM-J320FN) running Android 5.1.1, where the device failed to recognize the memory card, reported it as empty, and exhibited a continuous reboot cycle unless connected to a charger. Suggested solutions included restoring factory settings and checking the battery and USB connections. Ultimately, the problem was identified as a damaged memory card, which, when removed, resolved the device's malfunction.
