Opel Astra Z18XE 03: Traction Control Light, Engine Torque Reduction Malfunction C0256, ABS Issue
oidakra 45722 12
Why does a C0256 traction control/ABS fault on an Opel Astra Z18XE cause the engine to lose power, and what should I check first?
C0256 here usually means a fault at the left rear wheel speed sensor or its wiring, and that ABS/traction-control fault can trigger engine torque reduction, which is why the car cuts power [#8198023][#8198078][#8200247] Check the left rear wheel first, especially the speed sensor, the wiring near the wheel, and the toothed ring/reluctor for cracks or an incorrect sensor gap [#8198023][#8198078] The ABS and engine ECU are linked by signals such as vehicle speed and torque-reduction requests, so an ABS fault can directly affect engine operation [#8200247]
  • #1 8197843
    oidakra
    Rate: 99
    The problem is that when the traction control light comes on, the car does not seem to be smoking on one cylinder and throttles when driving.
    Error read by Launch:
    C0256 Engine Torque Reduction Malfunction (torque reduction fault)
    I also found such a description:
    C0256 "Electromagnet / gauge # 1 ABS rear left - fault"
    Would anyone be able to light it up a little? Because I do not know what this asterisk is.
    Best regards, Arek
  • #2 8198023
    wicher84
    Rate: 43
    Look at the left rear wheel. Most likely, he does not read the signal from the speed of this wheel or sees a different one than it is. I do not know how it is in your asterisk but in most cars there is an inductive sensor and such a ring with puffs (gear) I do not know how to call it professionally. If the wheel is cracked or the gap between the wheel and the sensor changes, then such circuses come out. There may also be damaged cables somewhere.
    matrixs
    Help: 60
    Rate: 313
    Probably a sensor to replace. You need to check the wiring next to the wheel.
  • #4 8198361
    oidakra
    Rate: 99
    Thank you for your interest in the topic and a quick response.
    Of course, I will check it, but try to further develop this topic, namely why the fault in the abs or tc system affects the operation of the engine.
    Cramps at all as possible ..?
  • #5 8198800
  • #6 8200180
    oidakra
    Rate: 99
    I can not find a connection anywhere between the abs and the engine anywhere
    bartek_j
    Help: 255
    Rate: 816
    And yet it is:
    - vehicle speed signal, from ABS to the engine controller
    - torque reduction signal from ABS to the engine control unit (occurs when ABS performs traction / ESP control)
    - sometimes there is a "rough road" signal from ABS to the engine controller, used, among others, by the ignition loss detection algorithm.
  • #8 8200391
  • #9 8200409
    sweeteck
    Help: 21
    Rate: 124
    I have a similar problem in the meriva 1.7 cdti, the same error in esp, and in addition the error in the engine driver simultaneously regarding the BARO sensor. It seems to me that it is about the error in the engine and the traction stops working, but I may be wrong
  • #10 8203494
    oidakra
    Rate: 99
    Thank you for the precise explanation of the subject. I will look into this rear left wheel.
  • #11 8203576
  • #12 8203784
    oidakra
    Rate: 99
    I diagnosed Launch
  • #13 19577302
    RossGee
    I had the same problem when my water pump went, I'd imagine it was because the engine started to run lumpy as the head gasket failed as a result. This was confirmed by a head clean and new gaskets and all codes cleared themselves.
✨ The discussion revolves around an Opel Astra Z18XE experiencing a traction control light activation and an engine torque reduction malfunction, indicated by error code C0256. Users suggest that the issue may stem from a faulty ABS sensor at the left rear wheel, which could be failing to read the wheel speed correctly or may have damaged wiring. The connection between the ABS system and engine performance is highlighted, noting that the ABS provides vehicle speed signals and torque reduction signals to the engine control unit, which can affect engine operation. One user also mentions a similar issue in a Meriva 1.7 CDTI, linking it to engine errors. The conversation emphasizes the importance of checking the ABS sensor and wiring for resolution.
