Seeking Torque Specifications for Camshafts, Bushings, Head on Opel Agila 1.0 Z10XE Engine
Szakuł880813 15435 2
  • #1 16622152
    Szakuł880813
    Rate: 14
    Hello, I need tightening torques for camshafts, bushings and head Opel Agila 1.0 engine z10xe
    Heinzek
    Help: 554
    Rate: 494
    Head:
    1 stage - 25Nm
    Stage 2 - 60 °
    Stage 3 - 60 °
    4th stage - 60 °
    Camshaft:
    gear wheel - 50Nm = 60 °
    bearings - 8Nm
    valve cover - 8Nm
    Main and connecting rods, too?
  • #3 16622618
    Szakuł880813
    Rate: 14
    you can specify, as I checked earlier, the connecting rods for the m 6 bolt found only 8nm + 60 degrees
