Profitability and Quality of 4K UHD TV for Digital Terrestrial Television Viewing
kamilk87 8244 5
  • #1 16951660
    kamilk87
    Is it profitable to buy a 4K UHD TV for watching digital terrestrial television? Is the quality of channels broadcast without HD will not be tragic over scaling the image and so it will not be so. "Pikseloza"? Can any of you share your insights?
    Thank you in advance!
  • #2 16951740
    Ludwik XVI
    Help: 1325
    Rate: 788
    Scaling is quite good.
    However, on FHD, the signal will not need scaling, so one problem is less :)
  • #3 16956329
  • #4 16956537
    Ludwik XVI
    Help: 1325
    Rate: 788
    LOCOLOCO wrote:
    If you have pixelosis, change it:
    - wires
    What cables should be changed on terrestrial DVB-T?
  • #5 16956644
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    In my opinion, the best picture is when the resolution of the signal and the matrix are identical. Each time you scale, the image deteriorates.
    HD image broadcast in Polish stations has a resolution of 1920x1080 and will be worse on UHD TV due to the scaling to UHD.
  • #6 16957727
