Best HDMI Cable for PS4 PRO: 4K Quality with Sony 4K TV & UPC Decoder - Is 8K/60Hz Worth It?
marles90 15315 15
What HDMI cable should I buy for a PS4 Pro connected to a Sony 4K TV and a UPC decoder, and is an 8K/60Hz HDMI 2.1 cable necessary?
A standard HDMI 2.0 cable is enough for this setup, so there is no need to pay extra for an 8K/60Hz “hyper” cable if your goal is 4K quality [#17923707][#17923706] For a PS4 Pro and a 4K TV, the important thing is that the cable is truly HDMI 2.0 compliant; one reply warns that marketplaces can sell older cables mislabeled as newer versions, so it is better to buy from a normal store with proper packaging/labeling [#17925021] Cheap, correctly specified cables such as AmazonBasics High-Speed HDMI were mentioned as sufficient [#17923706] If the run is very long, a better cable may make sense, but for normal lengths the thread recommends a simple HDMI 2.0 cable rather than HDMI 2.1 [#17925021]
  • #1 17923652
    marles90
    Hi. I need a very good HDMI cable that will connect my PS4 PRO to a SONY 4K TV + a TV with a UPC decoder. I found something like this on the allegro:
    https://allegro.pl/oferta/kabel-ultra-hdmi-2-1-8k-60hz-5k-120hz-4k-240hz-1m-7887864335
    The question is, is it worth getting into something like this? Or maybe it's better to look for something better? I care about 4K quality :) I am green on this issue, so please help. Thanks in advance.
    K3
    Level 30  
    Help: 153
    Rate: 429
    There is no point in paying extra for "hyper" cables. Anything that meets the HDMI 2.0 standard is enough.
    I bought "AmazonBasics High-Speed HDMI Cable", which is the cheapest, signed with the Amazon logo.
    sosarek
    Help: 9320
    Rate: 15532
    A standard HDMI 2.0 cable is more than enough.
    Z
    Pka, Poznań, 60-850
  • #4 17923739
    marles90
    What kind of cables are you currently using? Can you get them somewhere on the Allegro?
  • #5 17923766
    sosarek
    Help: 9320
    Rate: 15532
    I buy what they have in the warehouse, I do not pay much attention to the brand itself.
    Z
    Pka, Poznań, 60-850
  • #6 17925004
    E8600
    Help: 529
    Rate: 2520
    You probably had a cable in a lower HDMI standard, e.g. 1.2 or 1.3, that you saw the differences.
    Unfortunately, if the cable meets the standard supported by the receiver, there will be no difference because it is a digital signal.
    It is only profitable to take the more expensive HDMI cable when it is to be long, e.g. 10-20 meters.
    HDMI 2.0 is enough here. I would let go of Allegro, because there you can buy a cable in a lower standard, described as newer (for example, instead of 2.0 you will get 1.4).
    Go to a normal store and choose with a label / box in the amount of PLN 10-20 (depending on the length), it is important that it is version 2.0.
  • #8 17925032
    K3
    Level 30  
    Help: 153
    Rate: 429
    PawelChester wrote:
    You will get better colors, more details, better sharpness and better mapping of the distances between individual plans (near, far plan)
    Complete crap. The HDMI cable transmits the signal in digital form, i.e. bits. These won't fly faster, nor will they fly in pairs.
    Each pixel in the image has a defined brightness and color in the form of the RGB color palette. So any improvement in the image would have to be related to the signal processing by the cable.
    The effect of the cable on the image is the same as the effect of the type of Internet connection on the breast size of fictional actresses.
  • #9 17926535
    marles90
    The theory is already familiar, even beyond its means ;) Could you please drop some specific models + links; DZ thanks in advance!
  • #10 17926544
    sosarek
    Help: 9320
    Rate: 15532
    Search in stores as someone mentioned 2.0 compliant, not the thinnest of the correct length and use.
    Z
    Pka, Poznań, 60-850
  • #11 17927447
  • #12 17927675
    E8600
    Help: 529
    Rate: 2520
    Dude, understand that if the quality has changed (I do not deny it), you must have previously had an HDMI cable in a lower standard, probably 1.3 or 1.4, which stops working with 4K resolutions, which does not mean that if the cable is of a lower standard it won't work. It will work, but the picture will be worse.
    Unfortunately, the cheapest cables are often provided free of charge to newer devices that already support HDMI 2.0 (this is due to the manufacturer's savings).
    Some of the lagging cables in the 1.3 / 1.4 standard are sold massively at auctions as HDMI version 2.0. People buy it and then create such theories that there is a better picture on an expensive cable, this is because they simply bought a cable in the appropriate standard, not because it is branded = expensive.
    For example, if we have a TV with HDR, we already need an HDMI cable in the latest version 2.1.
  • #13 17927932
    K3
    Level 30  
    Help: 153
    Rate: 429
    E8600 wrote:
    HDMI cable in a lower standard, probably 1.3 or 1.4, which stops working with 4K resolutions, which does not mean that if the cable is of a lower standard, it will not work.
    Exactly. HDMI 1.4 works at 4K but only 30fps.
  • #14 17928349
  • HDMI cable categories and supported video modes
    #15 19271661
    Adam0018
    Help: 6
    I will dig out the topic, but at least I will write something that makes sense. Standard 2.1, 2.0 or lower affects the quality of the displayed image. The cable itself also affects the picture quality. As for 2.0, it will be High Speed HDMI Cable - possibilities: 720p, 1080i, 1080p, 4K @ 30Hz, 3D, Deep Color and Premium High Speed HDMI Cable - possibilities: 4K @ 60Hz, BT.2020 color space, 4 sampling: 4: 4, HDR or as you can see above for the 2.0 standard, there are different cables that allow for different possibilities. The 2.0 High Speed cable will not show us what Premium High Speed does. The standard 2.1, i.e. Ultra High Speed HDMI Cable, also remains - possibilities: 4K, 5K, 8K, 10K @ 120Hz, Ethernet. Cables below the 2.0 standard are Standard HDMI Cable - possibilities: 720p, 1080i. If someone does not see the difference, either the image sent from the source is of SD quality or TV from the bush company.
  • #16 19271820
    sylweksylwina
    Help: 1882
    Rate: 2355
    This was already said in post # 12.
The discussion centers around selecting the best HDMI cable for connecting a PS4 Pro to a Sony 4K TV and a UPC decoder, with a focus on achieving optimal 4K quality. Participants generally agree that an HDMI 2.0 cable is sufficient for 4K resolution at 60Hz, and that more expensive "hyper" cables do not necessarily provide better image quality if they meet the required standards. Some users emphasize the importance of using high-quality cables, particularly for longer distances, while others argue that the differences in image quality are negligible if the cables are compliant with the HDMI standard. Recommendations include avoiding low-quality cables often misrepresented as HDMI 2.0 and opting for reputable brands. The conversation also touches on the capabilities of HDMI 2.1 cables for future-proofing against higher resolutions and refresh rates.
TL;DR: "HDMI 1.4 works at 4K but only 30fps." For PS4 Pro + Sony 4K TV, a certified HDMI 2.0 cable is enough; 8K/60 isn’t worth it. Buy from reputable stores to avoid mislabeled stock. [Elektroda, K3, post #17927932]
Why it matters: This FAQ helps PS4 Pro owners get reliable 4K on Sony TVs and UPC decoders without overspending on hype.
What HDMI cable do I need for PS4 Pro on a Sony 4K TV?
Use an HDMI 2.0 cable. It handles 4K for PS4 Pro and a Sony 4K TV without paying for 8K claims. “Anything that meets the HDMI 2.0 standard is enough.” [Elektroda, K3, post #17923706]
Is an 8K/60Hz (HDMI 2.1) cable worth it for PS4 Pro?
Not for PS4 Pro. HDMI 2.1 (Ultra High Speed) is for up to 4K/8K at high refresh. If you don’t need 4K120 or 8K, HDMI 2.0 suffices. Save budget for games or storage. [Elektroda, Adam0018, post #19271661]
Do expensive HDMI cables improve color or sharpness?
No. If a cable meets your devices’ standard, image quality remains identical. Problems appear with non‑compliant or damaged cables. As the moderator noted, “there will be no difference because it is a digital signal.” [Elektroda, Anonymous, post #17925004]
Which cable spec should I search for to get 4K60 HDR?
Search for “Premium High Speed HDMI Cable.” It supports 4K60, BT.2020 color, 4:4:4 chroma, and HDR. Avoid plain “High Speed” if you need 4K60, since that tops out at 4K30. [Elektroda, Adam0018, post #19271661]
How do I avoid buying mislabeled HDMI cables on auction sites?
Skip questionable auctions. Some sellers list old 1.4 cables as 2.0. Buy from a normal store with labeled packaging. Expect around 10–20 PLN depending on length. [Elektroda, E8600, post #17925021]
Does HDMI 1.4 do 4K, and what’s the catch?
Yes, but only at 30 fps. Motion looks less fluid than at 60 Hz. For 4K60, use a cable that explicitly supports it. “HDMI 1.4 works at 4K but only 30fps.” [Elektroda, K3, post #17927932]
Why did my cheap HDMI cable look worse than a pricey one?
You likely replaced a lower‑standard cable. Older 1.3/1.4 units can limit resolution or frame rate. Some bundled cables underperform at 4K60. Moving to a true 2.0 cable restores full quality. [Elektroda, E8600, post #17925021]
When is a more expensive HDMI cable actually worth it?
Long runs. For 10–20 meter connections, better construction or active cabling helps maintain signal. Short runs rarely justify extra cost when the cable meets the standard. [Elektroda, E8600, post #17925021]
Should I avoid ultra‑thin HDMI cables?
Yes, avoid the thinnest options. Choose a proper thickness and the correct length for reliability, especially at 4K. That reduces dropouts and handshake issues. [Elektroda, sosarek, post #17926544]
What should I buy if I use a UPC decoder and a PS4 Pro?
Buy HDMI 2.0 cables. They will handle 4K sources like a UPC decoder and PS4 Pro. No need for boutique brands or 8K labels. [Elektroda, K3, post #17923706]
How to pick the right HDMI cable in three steps?
Do this:
  1. Pick HDMI 2.0 printed on the box.
  2. Buy from a normal store; avoid mislabeled auctions.
  3. Budget ~10–20 PLN; pay more only for 10–20 m runs. [Elektroda, E8600, post #17925021]
Will an HDMI 2.0 cable support 3D and Deep Color?
Yes. High Speed HDMI in the 2.0 era supports 3D and Deep Color. Premium High Speed adds 4K60, BT.2020, 4:4:4, and HDR. Check the package labeling. [Elektroda, Adam0018, post #19271661]
I use a Full HD plasma; can a premium HDMI still help?
On a 1080p display, any High Speed HDMI cable delivers full quality. Upgrading won’t improve sharpness, but a Premium High Speed cable prepares you for 4K later. [Elektroda, Adam0018, post #19271661]
What issues show up when a cable is under‑spec for 4K60?
Devices may fall back to lower resolution or frame rate, or the picture can drop out. Many bundled or mislabeled cables lag behind the needed spec and cause these failures. [Elektroda, E8600, post #17925021]
