Philips PFL426008K TV - Unresponsive with Repeated LED Blinking After HDMI Device Connection
cfirek 21864 8
  • #1 16953277
    cfirek
    Hello, the TV works, but for which time I do not want to start (most often after connecting any device under hdmi, but this is also not a rule, when watching netflix it can also spill) and its only sign of life is a flashing diode twice then break 3 sec and flashing again. Pulling out the plug doesn't help. The TV hangs up for some time, sometimes after an hour, and sometimes for a few days. The situation appears very often. What could be the reason? TV no longer guaranteed, sent to a local service, where they can't diagnose what happened. They mentioned something, PLN 300 paid and the TV still freaks out. Please help
  • #2 16953316
    zdzich42
    Help: 588
    Rate: 868
    They exchanged, deleted and you are not satisfied because the TV does not work properly? Return under the complaint.
  • #3 16953338
    lisek
    Service technician RTV
    Help: 6344
    Rate: 6872
    Phrase: 42pfl6008K 130 results found (0.19 s)
    Then in SM for QFU1.2ELA chassis, which means e.g. eror 2
    Enter description of the numbers from the white sticker (starts at 31 ......)
    * this is from the 42PFL6008K / 12 / 42PFL6158K / 12 model
    ps
    correct the model description in the subject
  • #4 16953339
    GanCegall
    Help: 339
    Rate: 1631
    Why didn't you return TV to this "service"? He hugged the money for nothing, and the problem is still ...
  • #5 16953361
    lisek
    Help: 6344
    Rate: 6872
    Recognize exactly the flashing LED (which), helpful
    link
    Link_czasem
    Rather, as part of the complaint return it for improvement,
    :!: have a serviceman read about this chassis in the forum!
  • #6 16953409
    mirex
    Help: 1950
    Rate: 1990
    Fox! Have you ever wondered who you are talking to?
    Take some control, huh?
    And in general, what to advertise here - they tried to fix it and that's it. The work costs money. Maybe you could go off the price, maybe you could do it for free. Just why Service, or according to some "service", after all said that the TV is not repaired.
    You only know the customer's opinion. And you know that the customer and hears what he wants to hear, not what is said to him, and says what he wants, and not necessarily what he heard on the website.
    Tip at the end - buy a new CD. I emphasize - new! You'll find out how much it costs.
  • #7 16953435
    lisek
    Help: 6344
    Rate: 6872
    :cry: kol.mirex "old serviceman" do you recommend Replacing the disc, not repair ??
    * you remember the series Dom i
    Mr. Popiołek kept saying "End of the world"
  • #8 16953479
    mirex
    Help: 1950
    Rate: 1990
    Yes. Absolutely and unequivocally. The author has no other choice.
    Sorry, he has - he can send this CD to repair for repair. ;)
    Just let him mark well so that he can be sure that he got exactly the same after repair. ;)
  • #9 16953550
    lisek
    Help: 6344
    Rate: 6872
    :!: you forgot to add: mark ... in a known secret place :D :cry:
    ps
    You talk like Lenin
    Trust is good but control is better
    :D
✨ The Philips PFL426008K TV is experiencing issues where it becomes unresponsive, indicated by a flashing LED light pattern after connecting HDMI devices or during streaming. Users suggest that the problem may relate to the TV's chassis, specifically the QFU1.2ELA, and recommend checking the error codes associated with the flashing LED. There are calls for the user to return the TV to the service center for further diagnostics or repairs, as the initial service attempt did not resolve the issue. Some responses suggest that replacing the main board (referred to as "disc") may be necessary, while others express skepticism about the service's effectiveness. Overall, the discussion emphasizes the need for proper diagnosis and potential replacement of components.
