Philips 32PFL3008H / 12 VES2.2e LA TV: No Backlight, Picture & Sound Present, LED Flashes 10x
jasiu_19 5364 7
  • #1 16330633
    jasiu_19
    TV Philips 32PFL3008H / 12 VES2.2e LA. No backlight. There is picture and sound. The LED flashes 10 times on startup. Where to start diagnostics? Any common faults?
    Best wishes
    Bartholomew
    Moderated By Mirek Z.:
    I removed the attachment, it has been here for a long time: https://www.elektroda.pl/rtvforum/topic3223138.html#15789294
  • #2 16331123
    W_marko
    Level 19  
    Help: 29
    Rate: 53
    You need to check whether there is power to the backlight. If so, the leds should be checked.
  • #3 16332175
    jasiu_19
    Unfortunately, the voltage on the backlight LEDs when starting the TV is about 40 V and drops to 0V. So rather the fault of the power supply itself.
    Any advice?
  • #4 16333302
    W_marko
    Level 19  
    Help: 29
    Rate: 53
    Check the leds.
  • #5 16333310
    jasiu_19
    What are these leds? For what voltage?
    The LEDs have a lens glued on them. I don't really get to get to them without taking my lens off. Can I just apply voltage to the entire tape input (e.g. 12V or 24V?). Because unfortunately I do not have a 40V power supply.
  • #6 16333330
    W_marko
    Level 19  
    Help: 29
    Rate: 53
    The leds are at 3V or 6V. I don't know what TVs are on this. I will scrape some paint off the path.
  • #7 16334975
    jasiu_19
    There are two pins on Leds: Vout and FB1s. After turning on the TV, Vout drops from 100V to 0V in about a minute.
    Probably I noticed damage to the D314 element. What's more, the R337 element instead of the 15R value has 100R (values from the schematic and PCB).
    Even though the TV has not been serviced or dismantled since it was new, you can see traces of amateur soldering there. The R337 element is literally sealed with tin, not soldered like the other elements :)
    What's more, the backlight blinks for a fraction of a second when turning on the TV from the remote control. It blinks twice at intervals of about 5 seconds. When connected to the power supply, they also flash for a fraction of a second once. Then there is a voltage of about 40V for the input of the entire LED strip.
    So I consider the diodes to be operational.
    I am asking for help, because this is my grandparents' TV, if I do not fix it this week, they will kill each other :D
    If possible, I would ask the moderator to move the topic to the website section, where I hope it will be more popular :)
    PS
    Unfortunately, the elements of D314 and R337 after replacement, and the situation remains unchanged. The backlight still only blinks twice for a split second.
  • #8 16353942
    jasiu_19
    I found a solution. It turned out that the backlight LED strip was damaged (as suggested by the colleague above). After replacement, everything works as it should.
    I consider the topic to be resolved, so I close it.
    Regards and thank you
The Philips 32PFL3008H / 12 VES2.2e LA TV exhibits a no backlight issue while still producing sound and picture. The LED indicator flashes 10 times on startup, suggesting a potential power supply fault. Initial diagnostics involve checking power to the backlight and the LEDs themselves. Subsequent investigation revealed that the backlight LED strip was damaged, which was confirmed by voltage readings dropping from 100V to 0V and visible signs of amateur soldering on the circuit board. After replacing the damaged LED strip, the TV functioned correctly, resolving the issue.
