Torque Wrench Setting - Adjusting Wrench from 19-120 nm to 17 nm (Model in Attachment)
Litwos7 4611 5
  • #1 17019704
    Litwos7
    Hello, I have a question that I would like to set the torque wrench to 17 nm and the one I have (I attach the model in the attachment) has a range from 19 to 120 nm, and can it be set somehow?
    • Torque Wrench Setting - Adjusting Wrench from 19-120 nm to 17 nm (Model in Attachment) klucz-dynamometryczny-quick-l_28771.jpg (23.82 KB) You must be logged in to download this attachment.
  • #2 17019728
    bubu1769
    Help: 1177
    Rate: 2374
    You set it to 19 and go back so that 7 aligns with the scale.
  • #3 17020492
    robokop
    Help: 1763
    Rate: 6372
    And what will guarantee that it will be 17Nm, if it is out of range?
  • #4 17020697
    darfur5
    Help: 267
    Rate: 1715
    Since its minimum value is 19 Nm, going below the scale does not guarantee correct operation.
  • #5 17020726
    bubu1769
    Help: 1177
    Rate: 2374
    For such small moments this key is not suitable anyway, what I gave gives the approximate value that goes to get on it.
  • #6 17022629
    enhanced
    Help: 963
    Rate: 883
    Exactly as above - on the website they say that it can be set but this pic on the water means by the eye you set it out of range. So as if you didn't set up. You must have a dedicated one that contains such a range.
