Insulation of 3x5m Tin Garage: Polystyrene, Panel Board, Condensation Prevention & Spacing
picek5566 5466 6
  • #1 16973838
    picek5566
    Hello, this is my first post on the forum so please be understanding.
    I bought a 3x5m tin garage, I would like to insulate it with polystyrene soon and put a panel board on it, the garage will be heated occasionally.
    My question is whether there must be a space between the sheet and polystyrene?
    And if I insulate such a garage, the water will not condense in it?
  • #2 16973909
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, the dew point will always be there. You can't avoid it. Glue the polystyrene to the sheet on the panels and it should be approx.
  • #3 16973915
    picek5566
    So the distance from the sheet does not have to be?
  • #4 16973925
    Jarosx9
    Help: 265
    Rate: 401
    There is something like PUR foam, maybe it's a better solution, or Polynor - something similar. I'm going to tinker with a carport and I'm wondering about it.
    Canned foam without aggregate
  • #5 16973936
    brofran
    Help: 650
    Rate: 1406
    You have not written whether it is an ordinary (simple, flat) sheet or profiled sheet. Usually garages are made of profiled type, then you stick polystyrene directly to it and there will be ventilation.
  • #6 16973944
    picek5566
    It is a trapezoidal sheet and I did not want to stick the polystyrene, just make a frame to insert polystyrene into it
  • #7 16973983
    brofran
    Help: 650
    Rate: 1406
    picek5566 wrote:
    make it as if a frame to insert polystyrene into it
    You can too, but it is more laborious.
    Moderated By ANUBIS:
    picek5566
    Last visit: Jan 21, 2018 7:45 PM
    I close the topic - no interest on the part of the author.
The discussion revolves around insulating a 3x5m tin garage using polystyrene and panel board, with concerns about condensation and the necessity of spacing between the insulation and the metal sheet. It is noted that condensation will occur due to the dew point, and polystyrene can be glued directly to the sheet. However, some participants suggest creating a frame for the polystyrene instead of direct adhesion, which is more labor-intensive. The type of sheet (trapezoidal) is also mentioned, indicating that ventilation is important in the insulation process.
