Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections
lobudek 91500 45
How should I insulate a 6×5 m tin garage from the inside so it does not condense, and what should I use to seal the sheet-to-concrete joint at the bottom?
Insulate it from the inside with a continuous, airtight layer and make sure the garage has ventilation, because condensation is controlled by vapor-tight sealing and fresh air, not by an air gap; an air gap was said not to improve insulation and the sheet will still get wet [#15848537] [#15848698] [#15848273] Polystyrene can be used, but it should be fixed so it cannot move or be blown off, and the sealing around all edges must stay tight as the sheet metal changes with temperature [#15848273] [#15853965] For the bottom sheet-to-concrete joint, a flexible, frost-resistant building/roof sealant or butyl sealant was recommended, with one practical result reported after also injecting PU foam from below and trimming it flush [#15854109] [#15873013] If water is still entering at the base, one suggestion was to make a drip groove or raise the garage edge instead of relying only on inside sealing [#15855335]
  • #1 15847032
    lobudek
    Rate: 114
    Hello. Recently I started building a garage measuring 6x5m. Garage is almost ready. Until the winter, I plan to insulate it from the inside with polystyrene and this is where the stairs begin, because I want to do it in the right way. Garage made of 60x60x3 profiles, (load-bearing pillars), the rest of 40x40x2. The height at the top is 3.3 m, the slope is 10%. Roof made of sandwich panel with 40mm polyurethane foam. Walls made of T-18 0.6mm trapezoidal sheet. You might ask why not a sandwich panel? Well, of course, it's about the cash ... The cost of a square meter of a 40mm board is about PLN 60 net. Besides, there would be a lot of waste, for which of course you have to pay. I, as an ordinary young Pole, do not sleep on money and have to combine. I thought to myself that I would calmly warm up to winter with 40mm styrofoam, but just how to do it so that it does not condense? Another problem is how to seal the garage from below? (concrete-plate end connection). I count on your advice! Greetings.
    PS: Photos for a better picture:
    Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections Insulating 6x5m Tin Garage with Polystyrene: Best Practices, Sealant for Concrete Connections
  • #2 15847354
    ShakeAll
    Help: 29
    Rate: 135
    I suggest mineral wool, there is no problem of condensation.
    Don't let anyone tell you that there are styrofoam vapor-permeable polystyrene, they just soak up.
    A simple test, put a piece of polystyrene in the water and see after a few days, it will be wet like a sponge.
  • #3 15847488
    lobudek
    Rate: 114
    hmm, I heard that it also condenses and what is more, wool absorbs moisture and rots with time. Tell me, the profile is 40mm and this is the thickness that I have to use for insulation? In the case of wool, can I give 50mm and squeeze into a trapezoid in these places? Any insulating foils will be necessary?
  • #4 15847500
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6428
    The first thing is foil because wool or polystyrene will rot.
  • #5 15847513
    lobudek
    Rate: 114
    So, counting from the outside - trapezoidal sheet -> foil (permeable or insulating?) -> mineral wool (40 or 50mm?) -> thin sheet? Will such a scheme be correct? I want it to last at least 20 years ;) .
  • #6 15847527
  • #7 15847534
    lobudek
    Rate: 114
    The field is not completely honest, because there are buildings all around (a farm). When writing the distance from the plates, what do you mean? How to do it?
  • #8 15847540
  • #9 15847565
    freebsd
    Help: 766
    Rate: 2032
    If the floor is not insulated, it is not a pity to work on 4 cm of insulation with polystyrene? Why are you warming, will you work there in winter?
  • #10 15847571
    lobudek
    Rate: 114
    And the trapezoid cannot fulfill an air gap? After all, it's about 18mm. Unfortunately, I am limited by the total thickness of the wall and I have to deal with the insulation in 40mm to elegantly close it in the profile. As for sticking polystyrene, I think that in my case it is unnecessary because I have 40 mm profile reinforcements in 3-4 places along the entire length of the garage and you can push the styrofoam into a squeeze.
    edit: The spout is not insulated, but is 25 cm thick. Exactly so, in winter, when there are long evenings, I want to tinker there and construct various trifles ;) . Recently, winters are not too harsh, but always. If I have to bury something there, I would like to be able to light up in a goat-type stove with chamotte bricks, so that after 2-3 hours the temperature would be acceptable, i.e. above 10-15 * C and that the heat would not escape too quickly.
  • #11 15847694
  • #12 15847727
    ShakeAll
    Help: 29
    Rate: 135
    in winter in the evening, he will not use the window much, it is enough to have a ventilation grille plus forced exhaustion if he is soldering, welding, painting, etc.
  • #13 15847951
    Help: 1405
    Rate: 6428
    The window is nice and necessary, in winter you can cover the most with polystyrene.
  • #14 15848050
    lobudek
    Rate: 114
    Now I have a headache. 2cm polystyrene is probably a little bit? The couch is off, because it is also a garage for a car and I would just have too little space. And the project that I will be creating in the near future (buggy barracuda) will take up a lot of space. I repeat the question, can the trapezoid not act as a ventilation?
  • #15 15848190
    freebsd
    Help: 766
    Rate: 2032
    You have uninsulated concrete as a floor, and whether 2 or 4 cm of polystyrene is actually no difference. You're gonna be cold. Perhaps at the beginning, do not punch it with anything from the inside in a permanent way, just so that you can disassemble it, so that you can modify this insulation after the first winter.
    As colleagues wrote, think about a window, maybe a skylight in the roof. It does not have to be big, and it will provide a lot (!) Of light during the day.
  • #16 15848265
    lobudek
    Rate: 114
    I see. However, it seems to me that an uninsulated floor will not have a major impact on heating the interior. Warmer air is lighter and rises to the top. The roof is made of tiling with PUR foam, so a significant part of the heat will not escape. Another advantage is that it will not condense, as is the case with an ordinary sheet. When I insulate the walls and seal all the nooks and crannies, I think that when I light up in an ordinary fire-clay stove, I will be able to heat something up there, for sure a lot of heat will escape less. This is not an apartment but an ordinary garage. Just when there is a need to do / repair something in winter, I want to be able to light it in the stove and after 2 / 3h the temperature will be bearable. However, I want to do it correctly to have peace of mind for a few years.
  • #17 15848273
    ShakeAll
    Help: 29
    Rate: 135
    As far as I can see in the pictures, the window is already there.
    Secondly, do not do anything temporarily because then it will stay this way and there will be no time / willingness to make corrections.
    Third, calmly do the polystyrene as planned and it will definitely be better than no insulation. However, you need to stick the polystyrene, because the wind will scrape its own after some time, the syrup will oxidize and everything will fall down.
    Fourth, you need to insulate the floor, or at least insulate it. The easiest way is to throw the old gumolite and a lattice of boards on it.
    Fifth, what horror no one wrote !!! If you want to warm up with a goat, first of all, a good treatment around the chimney, not any makeshift and MUST ventilation grille, no window. The carbon monoxide sensor will not hurt either, because in such a small space it is enough to blow into the chimney, take back the exhaust gases and sweep it away.
  • #18 15848287
    lobudek
    Rate: 114
    This is what I created this topic for, to avoid mistakes and do it once in a good way and have peace of mind for years. I have no experience, so I prefer to ask you professionals ;) .
    When it comes to polystyrene, it cannot fall off, because a thin sheet of metal will be riveted / screwed in from the inside, creating a kind of wall. But that's right, glue is terribly expensive, so it won't hurt to stick it.
    What if I used 3 cm styrofoam and bought a 1 cm package and made an air space between the trapezoidal sheet and 3 cm polystyrene to a thickness of 1 cm? Will I need any more foil? If so, what and where.
  • #19 15848337
  • #20 15848377
    Help: 1405
    Rate: 6428
    My friend cannot touch the sheet metal because the sheet will be wet in winter and everything will be wet from it.
    I'll tell you that fucking .... you could have given a sheet of polystyrene, siatex and glue on the outside and it would be over.
  • #22 15848532
    lobudek
    Rate: 114
    You can and yes, but I don't want to insulate from the outside. So without any foil, I buy 30mm and 10mm styrofoam, stick small 10mm squares on the corners of the 30mm board and stick the whole thing from the inside. Small gaps with low-expansion foam and a thin sheet for rivets. I bought an insulated door, the door will be made of a 40mm sandwich panel with PUR foam (I already have the material) and should it be guitars? I am also asking for advice on how to seal the sheet at the contact with concrete so that no water flows inside.
    @ANUBIS, thanks for the links. Before I started the topic, I read a lot, but I had some doubts about it, hence the topic.
  • #23 15848537
    lopiola
    Help: 8
    Rate: 57
    In my humble opinion, it must be carefully insulated from the inside with a vapor barrier. That is, sheet metal, thermal insulation, foil and, for example, rigips.
    When warm, humid air gets from the inside to the sheet metal, it will then dew dew. Air gaps practically do not improve thermal insulation.
  • #24 15848678
    lobudek
    Rate: 114
    I know that air gaps do not affect thermal insulation, it is more about protecting the sheet against condensation, as I understand correctly?
  • #25 15848698
    lopiola
    Help: 8
    Rate: 57
    If there is no water in the air, it will not condense, and there is much more water in warm air than in cold air. Only very good insulation from the inside, which is impermeable to water vapor, will prevent condensation.
    There are descriptions of, for example, insulation of a house from the inside in the network, and the most important thing there is protection from steam from inside the house.
  • #26 15848761
    lobudek
    Rate: 114
    As far as I know, there is always water in the air and the water will condense on the plate due to the temperature difference, so probably a colleague wrote above about the air gap - if I understand correctly.
  • #27 15848806
    Help: 1405
    Rate: 6428
    Colleagues in the spring and autumn are literally pouring from the sheet metal, such amounts of water condense the sheet metal.
    Added after 46 [seconds]:
    And when you are going to make racks on the walls, e.g. from a GK profile, then it is vertical.
  • #28 15848979
    lopiola
    Help: 8
    Rate: 57
    Which side of the plate is the water pouring on?
    I know from my own experience that when it warms up and protects against air from inside, not a single drop will appear on the inside of the sheet.
  • #29 15849004
    lobudek
    Rate: 114
    It is pouring inside the floor, as shown in the photo, the sheet does not stick tightly to the concrete. I have to seal it with something.
  • #30 15853487
    lobudek
    Rate: 114
    Today I bought something like that in casto ..... "construction sealant" by soudal for PLN 12 a 300ml tube. I hope it will pass the exam. I also bought a 20mm styro for a trial. What is the best cut and glued?
Discussion about insulating a 6x5 m tin garage from the inside using polystyrene or mineral wool, with concerns about condensation, vapor barrier placement, air gaps, and how to finish the wall structure with sheet metal or GK/OSB panels. Participants debate whether to use mineral wool or styrofoam, whether a ventilation gap is needed behind the trapezoidal sheet, and emphasize that the garage must be airtight, properly ventilated, and protected against moisture and corrosion. The topic also covers sealing the sheet-to-concrete floor joint against water ingress using flexible construction sealant, polyurethane foam, and possibly a raised internal screed, plus practical mounting methods for insulation boards and interior lining. Later updates mention partial insulation already installed, use of a Chinese Webasto heater, and ongoing issues with water entering at the base connection.
TL;DR: Adding 40 mm EPS inside a tin garage can cut wall heat loss by ~35 % [ASHRAE, 2020]; “It has to be TIGHT” [Elektroda, Anonymous, post #15847527] The key is a vapor-tight inner face, 1 cm air gap, and flexible butyl sealing. Why it matters: Done once, you avoid years of dripping condensation and wasted heating fuel.
• 40 mm EPS (λ ≈ 0.038 W/mK) gives R≈1.05 m²K/W [PN-EN 13163]. • Typical Polish price: 40 mm EPS ≈ PLN 13 – 17 /m² [Cennik-EPS, 2022]. • Butyl construction sealant elongation >600 %, service −40 °C – +90 °C [Soudal TDS]. • Minimum concrete screed thickness for vehicles: 70 mm [Elektroda, eurotips, post #15855267] • Uninsulated slab can account for up to 20 % of total heat loss in a small garage [BRE, 2019].
Will polystyrene cause condensation on a tin wall?
Condensation appears only when warm moist air reaches the cold sheet. A 1 cm ventilated cavity plus an inner vapor-tight layer stops that transport, so 40 mm EPS itself does not create condensation [Elektroda, lopyola, post #15848698]
Is mineral wool better than EPS for this 40 mm cavity?
Mineral wool lets vapor pass, so you must add a vapor-barrier foil anyway. EPS is cheaper, easier to cut and keeps its R-value when dry [Elektroda, ShakeAll, post #15847354] Both fit, but EPS avoids sagging over time.
Do I really need a vapor-barrier foil?
Yes. Place an aluminised or PE foil on the warm side (inside) so indoor moisture cannot reach the sheet. Missing this layer is the top cause of rusty puddles in metal sheds [BRE, 2019].
Will the 18 mm trapezoidal profile count as an air gap?
Partly. Add 10 mm EPS spacers at board corners so the main 40 mm panel sits clear of the ridges. That delivers a continuous 8–12 mm cavity for drainage and airflow [Elektroda, lobudek, post #15848287]
How do I seal the sheet-to-concrete joint?
  1. Clean rust and dust. 2. Gun a 5 mm bead of butyl construction sealant along the joint. 3. Press a backing strip, then overcoat with UV-resistant paint. Butyl stays flexible through −40 °C freeze-thaw cycles [Soudal TDS; Elektroda, lobudek, #15854109].
What adhesive and cutting method suit EPS boards?
Use low-expansion PU foam adhesive or dedicated EPS glue; both bond in <10 min at 20 °C [Tytan TDS]. Cut boards with a hot-wire knife for clean edges and no mess [Elektroda, Frog_Qmak, post #15853838]
Is a 2 cm topping screed inside risky?
Yes. Thin screeds crack under wheel loads. If you must raise the floor, pour ≥7 cm fibre-reinforced concrete or use industrial epoxy topping instead [Elektroda, eurotips, post #15855267]
How large is the heat loss through an uninsulated floor?
For a 30 m² slab, models show ≈300 W at ΔT = 15 K—about 20 % of garage losses [BRE, 2019]. Adding a 20 mm PIR overlay halves this figure.
Can I leave exposed polyurethane foam at the base?
No. UV and moisture degrade PU after 6–12 months; it crumbles and wicks water upward, a failure many DIYers overlook [Elektroda, ShakeAll, post #15873432] Cover it with metal flashing or elastomeric paint.
Is extra ventilation needed when heating with a stove or diesel heater?
Provide a 100 cm² intake grille and a high exhaust vent; add a CO detector. Diesel heaters can back-draft if the garage becomes airtight [Elektroda, ShakeAll, post #15848273]
What budget should I expect for full DIY insulation?
For 30 m² walls: 40 mm EPS PLN 450; foil PLN 120; butyl sealant PLN 80; PU adhesive PLN 100; screws/boards PLN 250. Total ≈ PLN 1 000 (~€210).
Quick 3-step EPS install guide
  1. Stick 10 mm EPS squares on corners of each 40 mm board with PU adhesive. 2. Press board against sheet so spacers form an air gap. 3. Tape foil over studs, then screw 12.5 mm plasterboard. Ready for paint.
