How to Stop Rainwater Leaks in Tin Garage on Concrete Slab and Improve Sealing
samsung18 74376 18
How can I stop rainwater from getting into a tin garage where the wall meets the concrete slab?
Seal the junction between the tin wall and the concrete slab with a plastic bituminous mass, and if needed make a small concrete slope/curb with a galvanized flashing so water is directed outside instead of into the garage [#14360723][#14341828] The key place to seal is the wall-to-slab joint around the perimeter [#14341830] If water still gets in, a linear drain or digging around the garage was suggested as the next step [#14341735] One user also reported success painting bitumen compound around the garage both inside and outside at the concrete joint [#15128266] Heat-welded roofing felt was mentioned as an option, but it may be hard to fit into trapezoidal sheet grooves properly [#14361002]
  • #1 14341676
    samsung18
    Rate: 82
    I have a tin garage on a concrete slab and when it rains the water flies in. What should I do with it? How to secure it?
  • #2 14341681
    Dacomos
    Help: 125
    Rate: 192
    samsung18 wrote:
    I have a tin garage on a concrete slab and when it rains the water flies inside what to do with it ?? how to secure it?
    The floor of the roof is leaking - fortune teller :-)
  • #3 14341725
    samsung18
    Rate: 82
    Water enters between the spout and the lower angle.
  • #4 14341735
    Dacomos
    Help: 125
    Rate: 192
    Then there is linear drainage or digging of the garage.
  • #5 14341790
    samsung18
    Rate: 82
    Added after 29 [seconds]:
    I've marked the place where the water enters.
  • #6 14341823
    wiene
    Rate: 53
    Is the garage floor above the ground? - if so, it may be enough to seal the wall structure angle with the floor
  • #7 14341828
    adam 660
    Help: 7
    Rate: 41
    Forge concrete at an angle and place a galvanized sheet, bent on the back of the wall wave, and rivet it in the place where the wall is fastened so that water from the wall flows down onto the sheet and outside, not inside. Checked, dry inside - I also made a larger plate under the tin and the water was constantly leaking.
  • #8 14341830
    wiene
    Rate: 53
    I just saw the photo - you need to seal the joints of the wall with a concrete slab.
  • #9 14360254
    samsung18
    Rate: 82
    What can this connection be sealed with?
  • #10 14360723
    wiene
    Rate: 53
    Solid plastic bituminous masses, eg Abizol G Tytan Professional, seal the entire garage around the perimeter.
  • #11 14360942
    samsung18
    Rate: 82
    I have already lubricated with disperbit and nothing came of it, the water goes
    I am thinking of sticking the heat-sealable felt to the sheet
  • #12 14361002
    wiene
    Rate: 53
    Bituminous masses, plastic stelae, e.g. Abizol G Tytan Professional, seal the entire garage around the perimeter - oki heat-welded roofing felt, but the walls are made of trapezoidal sheet metal and it will be difficult to place the roofing felt in the grooves of the sheet well
  • Raised interior floor edge and poured collar for leak sealing
    #13 14362101
    Alemucha
    Help: 89
    Rate: 216
    Quoting the poet "Water has it that it flows into the main river, to the Baltic Sea" - just convince her that flowing through your garage it will be uphill. A few cm of indoor floor is enough. I made a collar poured in the center around the perimeter of broken old asphalt, heated in a cauldron over the fire and a bit of a burner. But it can be concrete (the thickness of the profile that rivets the sheet)
  • #14 15119406
    evolution1
    Rate: 57
    I have a question. I have a tinplate, but no door (I have it reported as a lamp). There is a draft on each side (gaps on the sides and back of the garage), yet water collects on the beams under the roof on cooler days. How to control it, the car is drenched daily with zinc rain :-) I read to stick with polystyrene or vapor-permeable foil, but how to stick these beams?
  • #15 15128266
    cezar80
    Help: 94
    Rate: 67
    Buy bitgum in a car and paint it around the garage both inside and out (the square that is wrong with the concrete) I had the same problem and had been in peace for a few years.
  • #16 15135379
    evolution1
    Rate: 57
    Okay, but what will it be possible to paint the corner bead on the floor? Should I also paint these ceiling beams? I do not really understand.
  • Cold tin surface, not paint, causes condensation
    #17 15139142
    Alemucha
    Help: 89
    Rate: 216
    evolution1 wrote:
    Okay, but what will you do by painting the angle bar?
    Thread.
    More would be to remove the condensation of water vapor from physics. If the mixture of steam and air hits a partition which is colder than itself, then we have water. It does not matter if the partition is called a leaf, grass, beetle's wing in the desert or a tin plate. Heat the baking tray and the problem will disappear :) . You can, of course, cover the whole with a nanotube membrane and drain them properly, but the cost will "slightly" exceed the price of the tinplate.
  • #18 20746580
    Robinson74
    Rate: 159
    cezar80 wrote:
    Buy bitgum from a car dealer and paint it around the garage, both inside and outside. (the angle that sticks to the concrete) I had the same problem and have been fine for several years.
    The same problem - after rain, water leaked inside between the angle and the concrete?
    And Bitgum helped?
    Doesn't it emit any odors?
    Studio Języka Angielskiego
    Piastowska 18, Krosno, 38-400
The discussion addresses rainwater leakage issues in a tin garage built on a concrete slab, focusing on water ingress between the metal wall angles and the concrete floor. Key problems include water entering at the joint between the spout and lower angle, condensation on beams, and drafts due to gaps. Recommended solutions involve sealing the joint between the wall and slab using bituminous sealing compounds such as Abizol G or Bitgum, applied around the garage perimeter. Additional measures include forging a concrete angle with a galvanized sheet bent and riveted to direct water flow outside, sealing joints with plastic bituminous masses, and creating a raised indoor floor collar to prevent uphill water flow. Challenges with applying heat-welded roofing felt on trapezoidal sheet walls were noted. Addressing condensation may require vapor-permeable foils or insulation on beams. Overall, bituminous compounds are highly recommended for effective waterproofing and sealing of the garage perimeter to prevent rainwater ingress and condensation-related moisture.
