JBL T450 Wireless Headphones: Overcharged 9hrs, Won't Connect, White LED On - Battery Issue?
Majlosz01 70413 9
Why won’t my JBL T450 wireless headphones connect after charging for 9 hours, and could the battery have been overcharged?
Charging them for 9 hours probably did not overcharge the battery, because the headphones have built-in protection against overcharging; the more likely cause is that the battery is deeply discharged or the headset needs a reset [#17126118] Try holding the power switch for about 15 seconds, which made the headphones work again for one user [#17127904] [#18383567] If they still won’t charge or turn on, one reply suggests the battery may be too deeply discharged for the charging circuit to start normally [#17537154] In that case, the reported workaround was to briefly apply external power directly to the battery for about 20 seconds (about 4.5 V, 150 mA) to “revive” it so USB charging can begin again [#17537154] If the headphones are still under warranty, using the warranty was also recommended [#17137289]
  • #1 16976881
    Majlosz01
    Rate: 15
    I have a problem, I bought the JBL T450 wireless headphones. After unloading I connected them for the night. However, it turned out that the charging time was 3 hours, and I charged 9 hours. Now the headphones do not want to connect and the white LED for charging is on. Will they unload themselves? Is it possible that I have reloaded the battery? Please help.
  • #2 17126118
    lowermann
    Help: 11
    Rate: 100
    Charging time does not matter, the device has a built-in system to prevent overcharging of the battery. Probably they will be discharged themselves, only after what time? This is not known. Is there no reset button there?
  • #3 17127904
    Majlosz01
    Rate: 15
    After 15 seconds of holding the switch, they worked, But now there is another problem .. Well unloaded headphones connected to the charger. I landed 3h as it is written on a box, after which after disconnecting from the charger the headphones do not turn on, no diode is burning ..
  • #4 17128129
    lowermann
    Help: 11
    Rate: 100
    I do not know how it is in these headphones, maybe after disconnecting from the charger, when the headphones are charged, the diode does not burn at all, and only when the battery is weak it signals it with a diode?
    From what I've been looking at, it's when these headphones are turned on after pressing the power button for more than 2 seconds :)
    Did you read the user manual for these headphones?
  • #5 17137210
    Vrhedna
    Rate: 14
    Good morning,
    It seems to me that I have a similar problem - the headphones were connected for charging overnight, in the morning I noticed that the diode is still on.
    According to the instructions, just after charging, it should go out. The headphones do not respond to attempts to turn on, and the device with which they were paired does not find them.
    Could the author of the post write whether he was able to integrate / continue to work? And if it was sent to him for guarantees, has it been recognized?
    Thank you in advance for your reply, greetings.
  • #6 17137289
    Freddy
    Help: 1394
    Rate: 2821
    If the headphones are on warranty then use it.
  • #7 17536610
    andrzejkowm
    Rate: 21
    I had the same problem.
    In a situation when the headphones have discharged, I connected them to charging and left them overnight. In the morning they did not give any signs of "life" anymore.
    I gave them back for a guarantee and got back charged and working with information that everything is ok. Nothing has been repaired.
    Now I'm meeting this problem again.
    Someone managed to solve this puzzle? After all, I will not take them to the warranty shop after each discharge.
  • #8 17537154
    lowermann
    Help: 11
    Rate: 100
    I checked the problem on similar headphones. It was true that they were not up to jbl but the behavior was identical, connecting the headphones via the current meter to the usb did not indicate any power consumption at all. The problem was solved in the following way. I got into the headphone battery, shortly through the power supply (about 20 seconds) I initiated the connection of the power source to the battery (in my case 4.5 volts, 150 mA.
    After these actions, the battery "revived" and after connecting the usb power indicator, the meter showed that the headphones are charging.
    It is possible that the system can not initiate charging because it is too deep.
  • #9 17537688
    andrzejkowm
    Rate: 21
    Maybe you're right. Only in my opinion it is a factory defect.
    I gave back the second (second) handset to the complaint - now I am waiting for the service response in this matter.
  • #10 18383567
    Kotlet_mielony....
    Rate: 9
    Hi, I have the same headphones, and after charging about 4 hours, a white LED came on and nothing was happening, I couldn't turn on or squeeze the headphones. I read that someone held down 15 seconds and it worked and in my case also.
The JBL T450 wireless headphones are experiencing a battery issue where they remain unresponsive after being charged for an excessive duration (9 hours instead of the expected 3 hours). Users report that the white LED indicator remains lit, and the headphones do not connect to devices. Some users suggest that the headphones may have a built-in overcharge protection system, and others have successfully reset the headphones by holding the power button for 15 seconds. However, persistent issues have led some users to seek warranty service, with mixed results regarding repairs. A few users have attempted to manually revive the battery by applying a low voltage to initiate charging, indicating potential deep discharge problems.
