VW Passat B5 Sedan Rear Window Heater Issue: Button, Relays, & Troubleshooting Steps
Kamai 7908 3
  • #1 16978392
    Kamai
    Hello. I have a problem with heating the rear window on the passat b5 (sedan).
    After pressing the switch, nothing happens, the glass does not heat, and the button does not illuminate anything except the rear window icon (it lights up when the lights are turned on).
    I replaced the button but it did not help. Where to look for the problem? Is there a relay for the rear window heater? If so, where to look for it? And how to get there?
  • #2 16978493
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The relay is in the switch.
    Fuses working?
  • #3 16978992
    RADU23
    Help: 2428
    Rate: 1732
    Fuse No. 26- 30A.
    The mirrors heat? It is locked into one fuse.
    PS fuses are located on the left side of the dashboard. When you open the driver's door, this is the flap that needs to be opened
  • #4 16979154
    Kamai
    The mirrors do not heat up either. Thanks to speawga it is today.
    Added after 4 [hours] 3 [minutes]:
    I checked the fuses, it turned out that there was no wogule. Thanks for the schedule, the glass was very useful and heats up.
